It is currently Fri Jan 19, 2018 8:32 pm
PostPosted: Wed Jan 29, 2014 4:14 pm
Bosch(96046)? Gates(41084)? or Airtex? or does it matter?
and should I use some kind of sealant with the gasket?
BTW where can I get the Dayco timing belt tensioner 84060
thanks
db
PostPosted: Wed Jan 29, 2014 4:28 pm
http://www.ebay.com/sch/i.html?_trksid= ... &_from=R40
http://www.ebay.com/sch/i.html?_odkw=su ... p&_sacat=0
i usually go with gmb or itb water pumps
PostPosted: Wed Jan 29, 2014 4:32 pm
t3 ragtop wrote:
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313.TR0.TRC0&_nkw=Dayco+timing+belt+tensioner+84060&_sacat=0&_from=R40
:werd: I like GMB pumps as well , used them on all my projects
PostPosted: Wed Jan 29, 2014 5:07 pm
a.k.a Bum head
I always used orange copper RTV sealant, granted that was probably overkill. It's better to use a bit of sealant on both sides of the gasket than to find a leak after you've put everything back together. Especially with the waterpump.
Good stuff for sale!
PostPosted: Thu Jan 30, 2014 7:36 pm
Ditto on the GMB, they are new, not remanufactured.
http://www.ebay.com/itm/GMB-165-1080-Ne ... 79&vxp=mtr
However I did get one that had the pulley boss crooked on the shaft,
I didn't notice untill I installed it and ran a few hundred miles on it,
I was pissed.
I usually use Permatex Aviation Gasket Sealer on the gasket to the pump,
and a sparing amount of silicone on the block side. The permatex is
near impossible to get off once it hardens.
Regarding the tensioner, I usually get the Ebay timing belt kit.
It comes with the tensioner and is priced less than the tensioner
alone.
This one's a smokin' deal for 30.95
Belt, Tensioner, V/C Gasket, Cam Seal, Crank Seal, free ship
http://www.ebay.com/itm/85-88-Chevrolet ... 87&vxp=mtr
PostPosted: Tue Feb 04, 2014 7:45 pm
Thanks to T3Rag Top, DTM GTi, CJDavE, and Jamal for the great recs.
I did go with the timing belt kit and GMB water pump from 123 Auto Parts Store.
Very good prices. Now if I can only get the weather to cooperate I could get started
on this project.
Regards,
db
cron
