It is currently Tue Jan 16, 2018 6:11 am
 Post subject: trans oil.
PostPosted: Thu Apr 03, 2014 10:11 pm
Ok so with 252xxx miles and my sprint being 27 years old I am figuring the trans fluid probably could be changed. My question is what fluid is supposed to be in the 87 sprint turbo man. Trans? The local parts house guys couldnt figure it out. Thanks in advance.
 Post subject: Re: trans oil.
PostPosted: Thu Apr 03, 2014 10:35 pm
I use gm synchromesh or equivalent competitors brand syncromesh fluid. It seems to work well, it won't fix a broken transmission, but I have had it eliminate minor grinding on high mileage transmissions. It's good stuff, apparently has just the right amount of slip to help synchros do their job effectively.
That said, I fixed up maybe 100-200 mk1's years ago when they were plentiful and always changed trans fluid before I sold them, it was always a mystery what would come out when you pulled the plug! I remember motor oil, ATF, 80/90 gear oil and 75/90 coming out depending on who had worked on them last. Each trans with these various oils seemed to work fine. Go figure.
PostPosted: Thu Apr 03, 2014 10:43 pm
Thanks. Being as high mileage as it is I'll probably go with the syncro mesh.
PostPosted: Fri Apr 04, 2014 1:15 am
Bob, synchro works great, but a quality ATF, or synthetic motor oil from 5/30 to 15/40 or 20/50 will do the job too.
PostPosted: Fri Apr 04, 2014 8:14 am
Thanks mike. My boss is an amsoil dealer so I'll get some oil from him. Also gonna be ordering a cam fairly soon. And getting a ss turbo manifold built for it as well.
PostPosted: Fri Apr 04, 2014 12:01 pm
Amsoil has a synchromesh equivalent. I would use that.
PostPosted: Sat Apr 05, 2014 8:41 pm
Mobil 1 5w/30 works great.
It will tend to seep out if your seals have shrunk over the years.
Some dinosaur oil 5w/30 can help recondition seals and works
fine too. I've used 5w/30 from the 1st change on and swap the
fluid about every 3-4 oil changes and I have 700,000 miles on the
tranny, never had to crack it open.
I have a new project I'm going to try synchromesh on my
rebuilt tranny with an LSD.
Swepco Synchromesh. You can find it on Ebay.
http://www.swepcolube.com/products/swep ... sion-fluid
PostPosted: Sun Apr 06, 2014 11:37 pm
Went with the gm synchromesh cause it was readily available. Shifts so much smoother and got better mpg through the first tank. Thanks for the info all.
