It is currently Thu Oct 19, 2017 6:32 pm
 Post subject: dead lean on boost
PostPosted: Sun Sep 28, 2014 1:52 pm
Well I get the red rocket up an running. Trying to dial in the afm but no matter what I do it goes dead lean on boost above 4000 rpm in all gears. Even if I get the afm to run at 11:1 on idle it still goes lean. I took out the air filter to eliminate that and am using an autometer wideband. Any idea on the experts on what next. It's a more or less stock 91 t3 with just a bit of porting of the head. Boost gauge tops at about 8.5-9 psi
 Post subject: Re: dead lean on boost
PostPosted: Wed Oct 01, 2014 10:53 am
Nobody eh. I have already checked the hoses and obvious stuff. There are no vac leaks. And it idles right at 14.7:1 and runs normal until it gets over 5 psi boost
PostPosted: Wed Oct 01, 2014 1:19 pm
Is that a map sensor car or a vaf car?
PostPosted: Wed Oct 01, 2014 10:34 pm
""Dead lean on boost'' will mean dead pistons in a very short time. It doesn't take very many seconds of detonation to smoke a piston and possibly ruin the head and cylinder.
Ken..........
PostPosted: Wed Oct 01, 2014 11:03 pm
I know it does not have a map sensor. So must be the other. But I have never heard of it.
That's why I'm glad I installed a wideband. When we see it go over 15:1 we let off the gas.
PostPosted: Thu Oct 02, 2014 7:56 am
It could very well be a bad vaf (air flow meter). My 87 was doing the same thing for a while right before the vaf died completely and would run lean all the time. The vaf should be in the air intake somewhere close to the air filter.
PostPosted: Thu Oct 02, 2014 10:48 am
I was thinking that to. But I have 2 of them. And the one I'm using works better then the other one. But I might try the second one and play with technology settings a bit. It is running dead lean just on idle. But it can be adjusted. Wish I could change it to a hot wire Chevy style. That would make life so much easier.
PostPosted: Thu Oct 02, 2014 10:01 pm
Make sure the wiring connector is clean and making a tight secure connection.
Also make sure the flapper moves freely and is not sticking.
Good idea to check for codes. If any of the intake ducting clamps
are loose or hoses are cracked that can introduce unmetered air as
well and make a lean condition. Put up some pics of what you're working on.
Finally, you may want to bench test the unit against FSM specs before
making any adjustments.
PostPosted: Fri Oct 03, 2014 1:09 am
Most likely the VAF (the door is getting stuck), i have this exact issue until the car warms up. I think there is a way to have the bearing replaced inside. Is your car getting up to temperature? Mine is not as extreme as yours, i wont hit full boost (on purpose) and only let the AFR get to 16-17 (red) before switch gears. It seems as soon as the car gets warmed up i can get into 10-12 AFR with no issues.
PostPosted: Fri Oct 03, 2014 11:41 am
It does get up to temp. And quick. I know the door is not sticking because I can none it from closed to open no problem with no resistance. It runs better cold. Will hit full boost no problem running at about 13:1 it's once it warms up it causes the problems. But I'm back home tonight so I will try my other lid tomorrow. I also ordered a set of 275cc injectors. See what that does. But first we are going to pop the hood off and watch the fuel pressure gauge. Make sure that's not dropping. It has a higher flow/pressure pump but something else might be restrictions flow. Take a closer look at the fuel lines.
PostPosted: Sat Oct 04, 2014 1:03 pm
Well. Turns out the fuel pump we picked up was faulty. In the garage it ran perfect. But once on the road the pressure dropped like a rock. Installed new pump. Runs perfect now. Thank you everybody for all your help. Soon I will be starting the second swap so I hope it goes a lot better.
PostPosted: Sat Oct 04, 2014 9:00 pm
Glad ya got it figured out.
