It is currently Sun Oct 22, 2017 9:08 am
 Post subject: Lost power.
PostPosted: Tue Oct 14, 2014 4:49 pm
I was driving home yesterday, 1990 Turbo sprint started losing power. Pulled off the road turned off. Started once, got going, lost power again, pulled off road and left her there. I have to go back to pick her up. Could it be a fuel issue? Fuel filter plugging? I am suspecting my fuel tank needs to be replaced, possible rust in tank causing plugging?
If there is water in the tank would it be easy to pump out? For the life of me I cant remember off hand where the fuel filter is located. Any info appreciated.
 Post subject: Re: Lost power.
PostPosted: Tue Oct 14, 2014 6:55 pm
Sounds like full problem to me. The filter is right beside the tank on the drivers side I beleave. And yes. If you have water and or rust in the tank it will cause problems.if your tank is full what I do is disconnect the fuel filter and run the hose into a gas can. Pull the fuel pump relay and jump the pink and white with blue stripe wires. At least for my 91 that's the colors but it should be the 2 terminals at the front. Then turn the key to run and let the pump drain the tank. If you do have rust in the tank more then Likely you will need a new sock for the pump as well as a new full filter. And let's hope the pump is still good. Might want to check the presume before hand
PostPosted: Sat Nov 15, 2014 8:40 pm
@ssclown
I've had more than one 1985 to 1988 Sprint, Forsa, or Firefly do that and I wasted a whole pile of time thinking it was a fuel problem and trying to solve that when in every case it turned out to be a faulty igniter(or something like that inside the distributor) which started failing once it warmed up. ( electrical resistance in a metallic conductor increases with temperature). Replacing the distributor with a known to be good used distributor solved the problem every time. Wait 'til the car is stone cold and try starting it.
PostPosted: Sun Nov 16, 2014 12:05 am
Yes. If it only does it hot I would look at ignition. It sounds like what mine was doing when my pump was not putting out enough pressure. The way I had to test it was to remove the hood and use a presume gauge zip tied to the firewall and went for a drive. Was dropping to 20 psi over 3000 rpm. If you have water in the gas tank about the only way is to drop it. It a hard job on these cars. I can have mine out in about 7 min. But if it's never been out could be fun with rust. Be carefull not to break Any of the 4 bolts and have new hose clamps. Another thing to be carefull of is the sending unit tube rust and can break really easily. I just removed most of mine and ran rubber tubing. I would start at fuel pressure and go from there. And there is a fuel filter right beside the gas tank on the drivers side. Check it as well. If it's plugged it will run but lose pressure/flow in the higher rpms
PostPosted: Sun Nov 16, 2014 9:46 am
I have had my share of bad ignition modules (inside dizzy) on the turbo cars. they would always start and idle fine, but would cut out over 3,000 or 3,500 rpm.
even the dealership could not figure it out, they blamed it on one cylinder having lower compression. by 7 psi. asshats.
did my own troubleshooting on the car, finally I swapped the dizzy, and bang! 7500 rpm no problem!
I have had 3 of them go bad over the last 15 years, all on different turbo cars. but never on a non-turbo?
hmmmm.......
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
