It is currently Sun Oct 22, 2017 12:51 pm
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
 Post subject: Re: Igniter in mk2 swap
PostPosted: Mon May 25, 2015 7:10 pm
I have the tachometer working. Turns out the igniter was faulty, i replaced it with the spare one that came with the car.
However she still won't start. Previously the turbo light would only come on when I touched the gas pedal while cranking it. Now when I try to start it the turbo light stays on. So i think it is a problem with the distributor.
When I had the distributor cam tabs replaced, I removed the black magnetic piece with the 2 wire connector. Is it possible I damaged this piece or installed it incorrectly?
PostPosted: Mon May 25, 2015 10:57 pm
After opening the distributor again I found the words "DONT REMOVE" .... Face palm
I tried to reposition it and she is sputtering now, almost firing up. The turbo light is all over the place.
Is there any chance of fixing the distributor? Or should I find one from a 92-94 3 cylinder?
PostPosted: Tue May 26, 2015 2:13 am
a.k.a Bum head
CJDavE wrote:
I have a distributor left that was working when I pulled it. $10 plus shipling, if you want it.
PostPosted: Tue May 26, 2015 6:13 pm
Thanks, I have one lined up locally I should be getting tonight.
