It is currently Fri Oct 20, 2017 9:36 pm
 Post subject: Mk2 issues after swap
PostPosted: Wed May 27, 2015 2:26 am
Well I got the sprint started and it seems to run really nice besides a few issues.
The brake pedal is very hard
Idle surges from 3000-3500
And the accessory belt is squeeling badly
The brakes worked fine before the swap. The belt squeeling does go away and it seems to make the brakes a little easier to push, but still very hard. The car will accelerate without touching the gas.
Thanks for your help
PostPosted: Wed May 27, 2015 8:30 am
Tighten the belt. They need to be tighter than many people realize. If its cracked up replace it then tighten it. Sounds like you have left the brake booster vacuum line unhooked. It's a big(3/8" perhaps), rubber line that goes from back of engines, usually to a steel tube on firewall, then makes its way to brake booster.
PostPosted: Wed May 27, 2015 9:21 am
I have the brake booster connected. I will double check it is not leaking. Is it possible I mixed up the brake booster hose with another and that is causing the surging idle as well?
The brake boost hose is connect on the back of the intake, near the top on the passenger side.
PostPosted: Wed May 27, 2015 10:32 am
The surging idle is likely a vacuum leak or line hooked up wrong. Another cause of a surging idle is air in the cooling system. That will go away with a couple warm up/cool downs, it should burp out any air and idle down
PostPosted: Wed May 27, 2015 2:17 pm
The surging was definitely air in the cooling system. Fixed that.
3000 rpm idle was because the throttle was sticking to the fuel line. Bent the line back and it's steady at 1000rpm
Brakes are still hard. The vacuum line appears to be good. But I will check again for leaks
