It is currently Thu Jan 18, 2018 2:42 am
 Post subject: Rebuild Advice
PostPosted: Tue Jun 23, 2015 5:26 pm
Dropped my head off at the machine shop and they said all the valve are leaking. So now I'm doing a valve grind, new guides, stem seals, new valves etc. My thinking is with more compression now the rings will be more likely to give out.
I'll be doing a hone and crank grind/ polish. Where should I buy the rings, bearing, etc? Rockauto? ACL make bearing for this engine?
