It is currently Fri Oct 20, 2017 8:51 pm
 Post subject: Parts Catalog
PostPosted: Mon Sep 07, 2015 1:35 pm
Anyone have in their possession a Suzuki/Chev(circa 1987-88) parts catalog for our MK I?
Specifically looking for the diagram of the transmission with references to the name of
the part and the part number. Just would like a copy of the page(s) so I can research the parts needed to rebuild 1st gear.
Any information and/or guidance would be appreciated.
db
 Post subject: Re: Parts Catalog
PostPosted: Mon Sep 07, 2015 7:29 pm
db
Phil did A solid back in the day here is his How to R&R a G10 Transaxle
viewtopic.php?f=9&t=42589
95-3banger Did one
http://teamswift.net/viewtopic.php?f=9&t=50486
and I will add this is the shizznizle for $58
http://www.ebay.com/itm/Geo-Metro-Swift ... a2&vxp=mtr
PostPosted: Mon Sep 07, 2015 10:20 pm
i have an 1985 shop manual
PostPosted: Mon Sep 14, 2015 7:07 pm
Need to know the parts needed and the part numbers for the 1st gear repair
Here are some part names I got from a Haynes manual, but I need the Suzuki/Chevrolet #'s
Any thing I missed or can delete in this list for 1st gear repair? Thanks
Low speed sleeve and hub
countershaft 1st gear
1st and 2nd gear bearing
1st gear synchro ring
2nd gear synchro ring
low speed synchro ring
sliders?
shims?
Confused, but not giving up
Doug
PostPosted: Fri Sep 18, 2015 12:17 am
This is the diagram you need...
(I pm'd you the big file with the numbers included, anybody else
can contact me for the info.)
Best of luck finding any of the actual parts as much if not all of the
part numbers have been superceded. Though it's a big planet and I'm sure
there's some old stock somewhere or aftermarket stuff available.
May take a bit of digging, but if you're persistent enough it may pay off.
95-3banger Did one
JVS always comes through. :D Phils write up was a good reference for my first rebuild
in tandem with the FSM, as always there's a learning curve on doing it the first time.
And I forgot about 95-3 banger's..got to bookmark that one.
Here's my take..
http://www.teamswift.net/viewtopic.php?f=32&t=47916&start=125
And note the comment to run the tranny on jackstands(95-3banger post) to get the oil flowing,
with the LSD I had major noise with all those gears when I spun the tire by hand.
Thought for sure I lost a needle bearing loose in the case or some other assembly
catastrophy, but after spinning the wheels by hand, a lot, I mean a lot, the noise
majically disappeared once the fluid was distributed.
