It is currently Thu Oct 19, 2017 8:28 am
PostPosted: Sun Sep 20, 2015 4:27 pm
Just got one of those aluminum radiators from Ebay for my 91 Firefly. http://www.ebay.com/itm/251898033150?_t ... EBIDX%3AIT Looks as if everything is right, except it sits about an inch too high. Is there a different lower bracket that would make it line up right? Maybe the bracket for an automatic sits lower because of the extra transmission cooler?
Also, I just got my turbo off, it's putting oil into the intake. Doesn't seem to be any play in the impeller shaft. Should I just find a turbo specialist, or is there a rebuild kit that would be easy to put in?
PostPosted: Sun Sep 20, 2015 5:06 pm
a.k.a Bum head
Yes. The automatic cradle sits lower.
I believe you can get a turbo rebuild kit, but your results may vary.
PostPosted: Sun Sep 20, 2015 8:17 pm
jess (jardamuth) of turbine tech is now at turboms.ca rebuilding turbos for all makes and models. he has a long history with our cars and the ihi rhb32 turbos for them. i'm sure that he can rebuild it. :wink:
PostPosted: Fri Sep 25, 2015 3:34 pm
If you decide to attempt the rebuild you're self be aware the shaft has reverse threads. I didn't know this and ruined mine.
Edd
