It is currently Sat Jan 20, 2018 8:40 pm
PostPosted: Fri Oct 30, 2015 10:52 am
Long time lurker now ready to start my build.
The car is a 1995 geo 3/5 na
I had the chance to buy a complete 1991 stock turbo setup including wiring harness. The only thing that was missing was the block, pistons and knock sensor
I want to drop off the block to machine shop to get bored for the 75 mm vitara pistons and clean up the crank. The only thing i need is the thread of the turbo oil return line and knock sensor. I have located the location on the na block that they go but i have searched in vain for the thread dimensions. I read somewhere on here they are a british pipe thread but can not find anything definitive. I know many have converted the na block. (T3 ragtop and others).
I will be posting pictures this weekend of the car and of the parts ( for the last two weeks i have been just cleaning and inspecting parts as well as testing every sensor as per the fsm which i downloaded from cjdave's thread).
I thank you all for all the posts that are on here and the time taken to document what you all have done.
PostPosted: Sat Oct 31, 2015 2:44 pm
Here are some pictures of the car how it is now and the parts that came with the turbo setup that I bought.
PostPosted: Sat Oct 31, 2015 3:38 pm
Dropped off the block and crank to the machine shop today. They said that it would be 10 days, I hate waiting. I could not find the info for the knocksensor and oil return line thread size so I will have to do that myself once I find the info. 75 mm vitara pistons and .1 mm under for the crank skim the top and balance.
PostPosted: Sat Oct 31, 2015 4:51 pm
a.k.a Bum head
The oil supply line is the one that's threaded. Not the return line. It's just a press-fit flared tube. Not sure about the threads, but I'm fairly sure the knock sensor is a common metric thread. Match up the threads on what you have with a tap and die set and you'll have your answer. 8)
PostPosted: Sat Oct 31, 2015 7:06 pm
MAking new exhaust gaskets with sheet copper, drywall zip tool, and double stick tape. Also a picture of the oil return I am assuming and the threads that I do not know. That is the problem I do not have the knock sensor it is the one thing that I am missing.
PostPosted: Sat Oct 31, 2015 9:32 pm
a.k.a Bum head
Yup. That's the supply line, alright. The return/drain is drilled and pressed in just above the oil pan. It's just a gravity drain. The supply should thread right into an existing blocked off (with a hex socket plug) supply line in the block. I don't recall having to drill/tap that one. PM t3ragtop, he may recall the thread type for the knock sensor. Or my old build thread might have it, somewhere down a few posts.
Edit: Here it is. Granted it doesn't say what thread it was for the knock sensor, I know it was a common metric thread since I used my own tap and die set. There was no need to create a new oil supply port, it's already there. The rest of the thread talks about piston options:
viewtopic.php?f=32&t=12925
PostPosted: Sun Nov 01, 2015 3:28 am
Knock sensor, brand new:
http://www.aliexpress.com/item/mitsubishi-Engine-Knock-Sensor-E1T25171A/611178368.html
I am assuming that the idea I have that knock sensors are the same between Cultus G13b and G10 is correct, which I am fairly sure of, but you may want to double check.
Hope it doesn't break your $500 bank :wink:
PostPosted: Sun Nov 01, 2015 10:07 pm
Well I looked for the connector on the wiring harness and as per the wiring diagram this should be it. Teeth the link looks about the right size but the wrong connector I found these but too much
http://www.ebay.com/itm/Ignition-Knock- ... 2r&vxp=mtr
PostPosted: Sat Nov 07, 2015 11:08 pm
N/A engine comes out
On a side note I have been scouring everywhere looking fora wiring diagram for 89-91 canadian turbo. I have downloaded CJDave's but am unable to blow up and print and still read. If anyone has a good digital scan of it I would be greatfull.
Still searching for a knock sensor I have found some on ebay that I think are correct but at $160 I will keep looking for a used one.
PostPosted: Sun Nov 08, 2015 11:07 am
a.k.a Bum head
Here's a link to the original GIF, not sure if it's good enough, but I've mentioned to bredenal that I can clarify stuff for him if necessary. If/when I clear up any ambiguous labels, this link (and image) will always point to the best version!
http://starflowerstables.com/docs/Mk2_Wiring.gif
PostPosted: Sun Nov 08, 2015 12:54 pm
Dude, the knock sensor I posted is the correct part--yet, apparently the connection is different, so splice the connections or get a completely different connector???? (at a savings of $140...)
Anybody with a factory T3 that can confirm the part # and check the connection?
PostPosted: Sun Nov 08, 2015 2:56 pm
a.k.a Bum head
The part that OP posted has the right connector and looks a lot like the original.
PostPosted: Sun Nov 15, 2015 6:57 pm
Week end fun while the wife was away. I picked up the block and the crank from he machine shop on fri and have been building it all weekend. I was impressed with the machine work they took everything right to what I wanted and everything was within .0001 here are a couple of pics of the motor I had taken a bunch during the build but I forgot the sd card
After this I got the intake and fuel rail all in. All I have left is the oil return line to the pan from the turbo ( i have a na block no return fitting)
and the knock sensor I think I found one local "he has to find it in the garage" I might have to buy the one listed above and solder on a new connector. Anyone have a bad knock sensor they want to sell me the connector off off
As a side note is the black connector that I have pictured above the knock sensor connector? I have scoured the wiring diagram and it shows a R for red wire to it an this connector has 2 wires one r/bl one white but all of the other connectors on the engine wire harness are something else as per the diagram.
