It is currently Sat Feb 24, 2018 7:15 pm
PostPosted: Mon Jul 18, 2016 12:16 pm
This previous weekend I put in a rebuild engine into my mk2 T3. I also changed the engine wiring harness. Now my fan will not kick in. I tested it with a 12v source and it works fine, it would kick in like normal before I did this swap. Coolant temp gauge works like normal. Everything else is good, only the fan will not turn on
PostPosted: Mon Jul 18, 2016 12:40 pm
a.k.a Bum head
The gauge is not connected to the operation of the fan. There's a thermal switch that turns it on independently. Either it's faulty, not connected or the wiring has a break. I believe the switch is on the thermostat housing, check the connectors and go from there.
cron
