It is currently Sun Jan 21, 2018 3:33 pm
 Post subject: Advance timing gear
PostPosted: Mon Aug 15, 2016 9:23 pm
What is the difference between using an advance gear and adjusting the distributor for more timing?
 Post subject: Re: Advance timing gear
PostPosted: Mon Aug 15, 2016 10:18 pm
a.k.a Bum head
The gear changes the cam timing relative to the crank. The distributor changes the spark timing in relation to the cam and crank.
PostPosted: Mon Aug 15, 2016 10:33 pm
Thanks Dave.
Should I use a +10 gear or stock with increased boost and mild mods?
PostPosted: Mon Aug 15, 2016 11:07 pm
What car/motor?
PostPosted: Tue Aug 16, 2016 12:36 pm
It's an mk2 t3 in a vert
PostPosted: Tue Aug 16, 2016 5:53 pm
I got a 6* sprocket and turbo grind cam from mike- pulls better at low rpm, winds up easier.89 t3
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
