It is currently Sun Oct 22, 2017 1:37 am
 Post subject: Mpg
PostPosted: Sat Aug 27, 2016 1:29 pm
Ive been averaging about 23-25 mpg the car has 75mm bore with vitara pistons 15 psi on a garret gt1544 turbo fmic 226/395 cam only about 5k miles on fresh build with custom 2 1/4 exhaust had a ton of issues with vacuum leaks up until a month ago now it is finally driving amazing and hauls. a/f ratio idles between 14-15 and about 10.8-12 depending on boost so i really see no issues if this is just the mileage that is normal i have no issue with it im just curious if theres something wrong. I do drive pretty aggressive but the few times i babied it it wasnt much different. On a side note anyone know which hond springs will lower this thing?
 Post subject: Re: Mpg
PostPosted: Tue Aug 30, 2016 10:18 pm
When I was doing the daily driver on mine, it was 30-35 mpg.
I had the weight down right around 1400 lbs.
Is your tire size affecting your MPG calculations?
PostPosted: Wed Aug 31, 2016 5:28 am
When gas prices hit $4.50 in AZ I drove mine for couple of tanks without getting into boost as much as I could just to find out if it would get same gas mileage I was getting when it was new and unmodified . I hit 40mpg . Usually I was getting 35-37 . If you are getting 20's something is seriously wrong , you are in the boost 24-7 or your calculations are off for some reason
PostPosted: Wed Aug 31, 2016 4:11 pm
I was able to get 50mpg in a stock mk2 t3. That was 100% highway driving at 80km/h. 175/70/13 tires and stock 4-10 tranny.
PostPosted: Wed Aug 31, 2016 8:45 pm
The taller 185 60 14s could be doing it i suppose. the speedo is off about 3-5 mph depending on speed compared to gps
PostPosted: Wed Aug 31, 2016 9:15 pm
What is your compression?
PostPosted: Thu Sep 01, 2016 1:35 am
With the vitaras id assume high 7 or low 8:1
PostPosted: Thu Sep 01, 2016 8:11 am
Not compression ratio. Do a compression test. Curious what it is.
PostPosted: Thu Sep 01, 2016 7:17 pm
Ohh gotcha, ill bang it out tomorrow morning and get back to you with the info
PostPosted: Sat Sep 03, 2016 12:57 am
Just checked my post and it wasn't here. Anyway 95 100 95 leak down was good so i guess the vitaras are just really low compression making off boost pretty bad
PostPosted: Wed Sep 07, 2016 11:28 pm
i have almost the same setup as you, gt1544 75mm vitara fmic 2" exhaust factory cam (for now until i have money for a 3tech turbo cam) and run between 155-160 on all 3 cyl. with 10,000 km on the build and get 37 mpg driving it hard with 195/55r15 bfg sport comp tires 95-100 is WAY to low
PostPosted: Thu Sep 08, 2016 6:38 am
a.k.a Bum head
Were the tests done with a fresh battery and the throttle held open with all spark plugs removed and the injector harness unplugged? If not, you could get low numbers like that.
PostPosted: Thu Sep 08, 2016 9:08 pm
Battery is good throttle open injectors were still going and i pulled 1 spark plug at a time. Im also using a pretty old harbor freight compression tester so maybe ill borrow something a little more reputable and do the rest. Ill follow up with another test on monday. Taking the fam camping tomorrow. Does anyone know if the cam might be giving up compression with the overlap i know some larger cams on my other v8 motors can cause that (so ive read)
PostPosted: Thu Sep 08, 2016 10:27 pm
a.k.a Bum head
I can tell you for sure that leaving the other spark plugs in will effect your compression results. You'll need to do it again with no plugs in to get meaningful numbers. Leaving the injectors plugged in will cause fuel to build up in your oil. As you can imagine, that's a bad thing.
I can't remember what happened to my compression numbers before/after getting one of the 3tech cams. Suprf1y should know the answer to that, though.
PostPosted: Thu Sep 08, 2016 11:15 pm
It definitely will, but not enough to make a motor with good compression seem low. It's a pretty mild cam
PostPosted: Fri Sep 09, 2016 12:02 pm
I am only getting 360km to a tank at best in my car
It's a pig
___________________
89 Swift gti
