It is currently Fri Jan 19, 2018 2:12 am
PostPosted: Tue Sep 05, 2017 7:28 pm
so my oil feed snap
instead of using another one from the old turbo which I'm worry it will happen like this again, have anyone try one of these?
http://shopping.kinugawaturbo.com/turbooilfeedlineandreturnpipeihirhb3rhb31rhb32.aspx
http://www.ebay.com/itm/Turbo-Oil-Feed-Line-Return-Pipe-IHI-RHB3-RHB31-RHB32-/382188142338?epid=1245534086&hash=item58fc303f02:m:mwUvt634Cl8duiP4lCuuq2g&vxp=mtr
http://www.ebay.com/itm/MAMBA-Turbo-Oil-Feed-Line-Kit-For-IHI-RHB3-RHB31-RHB32-Hitachi-HT05-HT06-/262895277830?hash=item3d35c79706:g:CJUAAOSw7GRZL-gr&vxp=mtr
1992 Geo Metro Convertible (with mk2 g10t)
PostPosted: Wed Sep 06, 2017 6:01 pm
Hi Pascal
Yes i replaced the original oil feed line with the Mamba one and it worked perfectly but instead of the oil line by the pump I relocated the line next to the oil pressure switch, the reason is at least the oil is filtered before going to the turbo. I know that the engineer designed like that for a reason but I don't drive hard so it's still working perfectly for me :D
Cheers.
PostPosted: Fri Sep 08, 2017 8:29 am
thanks for the reply, I'll try source some banjo and hose locally first, if nothing then I'll get the MANBA kit
PostPosted: Fri Sep 08, 2017 5:19 pm
Mine snapped just like yours and I simply clamped on high heat/pressure rubber hose and its help up fine even on a modified engine/larger turbo
Stainless lines look nice but really not necessary
