http://www.teamswift.net/
rhb32 oil feed / return replacement
http://www.teamswift.net/viewtopic.php?f=32&t=62992
Page 1 of 1
Author:  Pascal [ Tue Sep 05, 2017 7:28 pm ]
Post subject:  rhb32 oil feed / return replacement
so my oil feed snap
instead of using another one from the old turbo which I'm worry it will happen like this again, have anyone try one of these?
http://shopping.kinugawaturbo.com/turbooilfeedlineandreturnpipeihirhb3rhb31rhb32.aspx
http://www.ebay.com/itm/Turbo-Oil-Feed-Line-Return-Pipe-IHI-RHB3-RHB31-RHB32-/382188142338?epid=1245534086&hash=item58fc303f02:m:mwUvt634Cl8duiP4lCuuq2g&vxp=mtr
http://www.ebay.com/itm/MAMBA-Turbo-Oil-Feed-Line-Kit-For-IHI-RHB3-RHB31-RHB32-Hitachi-HT05-HT06-/262895277830?hash=item3d35c79706:g:CJUAAOSw7GRZL-gr&vxp=mtr
Author:  92convert [ Wed Sep 06, 2017 6:01 pm ]
Post subject:  Re: rhb32 oil return line replacement
Hi Pascal
Yes i replaced the original oil feed line with the Mamba one and it worked perfectly but instead of the oil line by the pump I relocated the line next to the oil pressure switch, the reason is at least the oil is filtered before going to the turbo. I know that the engineer designed like that for a reason but I don't drive hard so it's still working perfectly for me :D
Cheers.
Author:  Pascal [ Fri Sep 08, 2017 8:29 am ]
Post subject:  Re: rhb32 oil feed / return replacement
thanks for the reply, I'll try source some banjo and hose locally first, if nothing then I'll get the MANBA kit
Author:  Rustyoid [ Fri Sep 08, 2017 5:19 pm ]
Mine snapped just like yours and I simply clamped on high heat/pressure rubber hose and its help up fine even on a modified engine/larger turbo
Stainless lines look nice but really not necessary
http://www.phpbb.com/
