It is currently Wed Oct 18, 2017 1:31 am
 Post subject: Suzuki Forsa turbo
PostPosted: Sat May 29, 2004 11:51 pm
need some help guys..thinking of buying a turbo forsa..found this one
except for one thing...it idles fine..but drive if t for about 10 minutes.
it overheats and the engine dies......any ideas guys,could it be a
faulty ECU or turbo ?
PostPosted: Sun May 30, 2004 3:22 am
If its overheating to the point of the engine stalling I would worry about something seriously wrong with the cooling system. Could be: leaky or clogged radiator, damaged hoses, dead thermostat, cracked head/block, blown headgasket, clogged heater core, etc. Did you notice any visible evidence of coolant escaping? (puffs of steam from under the hood, white smoke from tail pipe, coolant dripping from engine parts, puddles on ground)
PostPosted: Sun May 30, 2004 9:10 am
Deadbeat
Deadbeat
is it going to normal operating temperature or does the temperature meter in ur instrument panel in the red? if it just goes to normal operating temp and then dies then it could be ur ecu, i had the same problem when my car would warm up a bit it would just shut down
1999 G13B Metro
lotta Mods
2002 Sentra SE-R
 Post subject: Suzuki forsa turbo
PostPosted: Sun May 30, 2004 10:42 am
Ghost...it just goes to normal operating temp then dies.even the
owner figures that is what it is..wish I could be sure though
PostPosted: Sun May 30, 2004 12:40 pm
i think that's what it is, too. the ecu will run at it's preset until the engine comes up to temperature, then when the controls come up the car dies. time it when it happens and if the time is consistant that might be the trouble.
i've also seen that kind of thing happen with an internally collapsed muffler or a plugged up catalytic converter. the car will start and idle fine, but as soon as you start driving it's like you switched the ignition off.
PostPosted: Sun May 30, 2004 1:03 pm
I don't think it's the muffler...it has a Flowmaster stage 2,almost
straight through you might say..as for the cat, it dosen't have one
so I think we all might be right..must be the ECU.Anyone have any
idea what one would cost..be a bitch trying to find one,parts are getting
pretty rare on those
PostPosted: Sun May 30, 2004 9:26 pm
Deadbeat
Deadbeat
got mine at a junk yard for 75 dollars at the dealer it would have cost me 1300 bucks
but yeah im pretty sure its ur ecu go to a junk yard get a ecu for the same year make and model of ur car and hope that fixed ur prob
1999 G13B Metro
lotta Mods
2002 Sentra SE-R
