It is currently Wed Oct 18, 2017 1:31 am
 Post subject: Turbo 1.0L
PostPosted: Mon May 31, 2004 11:54 pm
I currently have a 1.0L in my 95' Metro, I wanna boost it with a Sprint or Firefly turbo. What are the main things I should know about doing this and will it bolt up correctly? Also where can I get a performance pulley from?
PostPosted: Fri Jun 04, 2004 1:34 am
For a turbo setup contact Jardamuth http://www.teamswift.net/profile.php?mo ... file&u=232
Otherwise a bit of reading would find you this:
http://www.teamswift.net/viewtopic.php?t=7491
and the Sticky at the top of the forum:
http://www.teamswift.net/viewtopic.php?t=4890
 Post subject: GL turbo kit..
PostPosted: Thu Jul 08, 2004 9:51 am
You can check out this site for pic of turbo Swift GL..cool
http://community.webshots.com/album/152968639MULSmY
WIN LOSE never mind, PATTERN must be nice!
PostPosted: Thu Jul 08, 2004 5:19 pm
according to jard, the turbo engine has a forged crank and lower compression pistons that will handle the boost. the turbo engine also has a multipoint injection system with 3 main injectors that are fitted directly on the head instead of the single injector in the throttle body of a NA 3 banger.
the engine bay wiring harness and ecu is different as well to accomodate the the multipoint system. the addition of boost requires a lot more fuel.
i've talked to a few guys who have just bolted on a turbo and used light boost, a pressure hood over the throttle body, and a larger injector and run turbos without doing anything to the engine internals but it doesn't seem like that would get you much in the way of horsepower.
i keep these pics in my turbo file just for laughs. have a look. :razz: :roll:
PostPosted: Thu Jul 08, 2004 7:31 pm
Actually, all 3cyl. cranks are the same. I also thought they were forged, but have since found out that they are not. The stock pistons will take boost with no problem, as long as your fuel/timing is right. Raven apparently uses the IHI RHB3 on an otherwise stock 3cyl. at low boost(5psi), and experiences no problems. I can't remember the horsepower, though.
PostPosted: Thu Jul 08, 2004 9:00 pm
thanks mike,
that gives a lot of creedance to what the crazy boyz were telling me about bolting turbos onto metros, cranking the boost up, and spanking the honda crowd.
they said that they would pop 12 to 16 pounds of boost on the little 3 bangers and run the hell out of them. when they blew up, they'd just throw all the goodies on another car and go racing again.
personally, i was all for just swapping the head, intake, oil pan, ecu and wiring, and the other bits that make a turbo onto my NA short block for a quick job of it. i still might take a weekend and do it! :shock:
 Post subject: .....
PostPosted: Thu Jul 08, 2004 11:41 pm
Senior Member
A fellow here is running a very basic setup in 3/4 tuned state with 80hp atw and a heap of torque. Running custom intake manifold and 3 injectors. Lots more to come on this test engine.
PostPosted: Fri Jul 09, 2004 4:49 am
Very intresting pics.
Tell us something about the injectors.
If you cant race it or take it to bed its not worth having.
PostPosted: Sun Jul 11, 2004 1:44 am
HEY!!! Thats exactly what I need for my supercharger set up!!!!! What injector did they install? Was it in stock location? What did it come from???? If I could only buy that hood. hmmmm :)
90 Sprint supercharger in a box waiting for warm weather.
85 Fiero GT solo racer custom interior.
81 Audi 4000
PostPosted: Sun Jul 11, 2004 3:22 am
Damn, that's some nasty-ass looking turbo hardware. I'm sure they do the job, but daaammn! :shock: Them flanges look kinda thin too. :? Oh well, whatever works... :lol:
