It is currently Sat Oct 21, 2017 10:00 am
 Post subject: gas saving mods
PostPosted: Thu Mar 27, 2003 8:46 pm
banned
<!--EZCODE BOLD START--><strong>anything i can do to burn less gas?</strong><!--EZCODE BOLD END--><!--EZCODE BOLD START--><strong>a more restrictive exaust? intake?</strong><!--EZCODE BOLD END--> <p></p><i></i>
 Post subject: Re: gas saving mods
PostPosted: Fri Mar 28, 2003 7:21 am
buy a vacuum gage. Keep the manifold pressure in high vacuum as much as possible. Avoid high revs. Thats about it.<br><br>--Roy <p></p><i></i>
PostPosted: Fri Mar 28, 2003 8:52 am
are you slowing your car down?<!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <br><br>ltes see...also<br>1. the amount of air your intaking<br>2. stock fuel psi,if you have done anything to it<br>3.not too big of an exhaust<br>4. got any heavy stereo equipment?<br>5.stock wheels.<br>6. and especialy rev less<br><br>basically, as close to stock as you can.<br>do you want to do all that? <p></p><i></i>
 Post subject: actualy ...
PostPosted: Fri Mar 28, 2003 9:39 am
about the exhaust i do believe the the bigger the exhaust and therefore the less backpressure, the better the fuel economy !<br><br> <p></p><i></i>
PostPosted: Fri Mar 28, 2003 9:43 am
that too <p></p><i></i>
 Post subject: While youre at it..
PostPosted: Fri Mar 28, 2003 10:45 am
The mad quebecer
The mad quebecer
Make sure you have good compression at every cyl. Worn rings, burned or carbon coated valves and bad spark plugs lead not only to power loss, it burn fuel too.<br><br>Jar <p></p><i></i>
 Post subject: Re: While youre at it..
PostPosted: Fri Mar 28, 2003 7:32 pm
place a little block of wood under the accelerator so you can't floor it, <br><br>tune your car to run lean?<br><br>restrictive air intake,<br><br>also depends a lot on your driving,<br><br>eg, drive in the slow lane, when on the motorway/highway tailgate a big truck to cut down on wind resistance (usless fact: did you know that at 80km/h you use half the power the engine produces to cut the air/wind in front of you) <p></p><i></i>
PostPosted: Sat Mar 29, 2003 4:31 pm
banned
about the exhaust i do believe the the bigger the exhaust and therefore the less backpressure, the better the fuel economy !<br><br><!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> <!--EZCODE EMOTICON START :eek --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eek.gif ALT=":eek"><!--EZCODE EMOTICON END--> really? <p></p><i></i>
PostPosted: Mon Mar 31, 2003 6:02 am
I'd imagine that the more air in the cyl the better the fuel burns...hence if you don't get up it everywhere you go it should be more efficient!...advance the timing till the engine begins to detonate then retard it 2 degrees....this is a fairly simple way of leaning out you mix....or bugger it..just screw with your mixture screw!!!! you know thats why its tamper-proof!!!!!<br><br>In a way just view all performance mods as "economy mods" as when you not using the power your not using the fuel....also its a good reason to tell you other half!!!!! <p></p><i></i>
PostPosted: Mon Mar 31, 2003 9:59 am
banned
where the hell is my mixture screw?????<!--EZCODE EMOTICON START :rolleyes --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/eyes.gif ALT=":rolleyes"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Mon Mar 31, 2003 4:40 pm
shit...i may be thinking of the carbs...never mind....the mixture would probably be controlled by the computer...in which case you have to justify you insanity....is the money you'd save on fuel worth the mods your ganna make.....keep it simple...its easier to explain to stupid people when you beat them in a race!!!!!<!--EZCODE EMOTICON START ;) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Mon Mar 31, 2003 9:01 pm
banned
yah the carbies have a mixture screw, but im forgettin all that crap now, im back into my speed mode, thanks anywayz<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> <p></p><i></i>
PostPosted: Tue Apr 01, 2003 12:28 pm
BETTER gas mileage? I get 45mpg, with modifiactions and a happy giggle pedal <!--EZCODE EMOTICON START :) --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)"><!--EZCODE EMOTICON END--> what more could I ask for? <p>Tony<br><br>Proud owner of<br>1970 AMX 360/auto with A/C<br>1989 Suzuki Swift GTi<br></p><i></i>
PostPosted: Tue Apr 01, 2003 1:01 pm
i think you can probably keep everything you have and still get good gas milage as long as you drive normal. <p></p><i></i>
PostPosted: Tue Apr 01, 2003 2:00 pm
using premium will get you better mileage.......... <p>Tony<br><br>Proud owner of<br>1970 AMX 360/auto with A/C<br>1989 Suzuki Swift GTi<br></p><i></i>
PostPosted: Tue Apr 01, 2003 10:25 pm
banned
hmmm, i guess we are different cause every modded GTi i know drinks g<!--EZCODE EMOTICON START 0] --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/alien.gif ALT="0]"><!--EZCODE EMOTICON END--> as! <p></p><i></i>
PostPosted: Wed Apr 02, 2003 4:29 am
Any one heard of an ecotek valve??????? They are supposed to reduce fuel consumption and slight power and torque increases. Dunno about the power increases but from what i have heard it does wonders for fuel consumption.<br> <p></p><i></i>
 Post subject: save gas
PostPosted: Wed Apr 02, 2003 7:53 am
Remove your seats.<br><br><br>the removal of the seats prevents any unneceessary transportation on the transporters behalf of any or all personnel which results in unwanted fuel consumtion and noticeable loss in fuel economy thus altering the exelent percentage of distance to fuel ratio to a now decreased distance to an even more percentage of consumed fuel causing the commuter to "come up out the pocket" when he/she dont got no dough <p></p><i></i>
 Post subject: Re: save gas
PostPosted: Wed Apr 02, 2003 10:31 am
banned
shut u<!--EZCODE EMOTICON START :lol --><img src=http://www.ezboard.com/intl/aenglish/images/emoticons/laugh.gif ALT=":lol"><!--EZCODE EMOTICON END--> p <p></p><i></i>
