It is currently Fri Oct 20, 2017 4:25 am
Post new topic Reply to topic  [ 184 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
PostPosted: Thu Apr 27, 2006 7:03 pm
I just put the new head on, and mileage has jumped 5 mpg to 43 so far... But i was hot rodding it on that tank...
I have my EGR disconnected... I have always thought those things reduce mileage... but i read a post in here that they increase mileage.... Any proof either way?
93 Geo Metro 1.0 N/A Manual
Accell Supercoil, MSD wires, K&N Filter
Swift +10 Cam sproket & 10.5:1 Cyl head, port/polish, Economy Cam.
PostPosted: Thu Apr 27, 2006 8:03 pm
I wonder why you're only getting 43 mpg? Guess some Metros do better than others...
My Metro XFi has slowly gone from last summer's 54 MPG average to 46.5 MPG average now... not sure if it's the fuel or if I just need to do maintenance... Anynow I've ordered a 3tech head just like you got only mine will have 11 to 1 compression and I'll put the Singh grooves in it.
Jeremiah
1993 Metro Xfi, 312k miles
55 MPG daily driver
PostPosted: Fri Apr 28, 2006 1:47 am
i got about 38-57 MPGs in my Metro depending on where and how fast i was driving, does any one miss the days where $5 could give us over half a tank, i have an idea if no one bought gas in the u.s. for 2 days OPEC would lose $30+ billion in those 2 days if i lost $30 billoin in 2 days i'd listen $30,000,000,000 thats alot of zeros and lower gas prices would help the counrty and auto makers
lower gas prices= more money to PAY bills with and for the auto makers lower petroleum prices would allow more money to be spent in engienering, devolopment, and production
there's no bad ideas on performance, just bad endings and hospital bills, lots and lots of hospital bills
PostPosted: Fri Apr 28, 2006 2:13 am
Jeremiah
What are the Singh grooves???
PostPosted: Fri Apr 28, 2006 9:04 am
The Singh grooves are talked about in this fuel economy forum http://www.teamswift.net/viewtopic.php?t=17077. What they do is prevent pinging and detonation, allowing a much higher compression ratio to be used. People have reported 30% more fuel economy with the higher compression using the grooves.
Jeremiah
55 MPG daily driver
PostPosted: Fri Apr 28, 2006 9:32 am
I'm interested to see the effect of those grooves on the G10, but I doubt it'll do much. They'd likely work better with a larger piston providing a bit more quench area, or perhaps a higher CR. The G10 doesn't seem to have much quench, and these grooves kind of rely on it.
PostPosted: Fri Apr 28, 2006 11:33 am
'93 Metro 4-dr, 1.3 SOHC 5-speed, 3tech cam K&N, 2" exhaust, 4.11 final drive, 185/60/14 tires-about 435 km's combined city/hwy.
If you ask why, you don't get it.
If you ask how, you get it.
PostPosted: Fri Apr 28, 2006 2:36 pm
As I understand it, when you shave a head you make the size of the quench area larger, just cause you "flattened the top of the mountain" so to speak. Less "valley" area left in the head after it's been shaved for higher compression.
Somender Singh says it takes very little quench area to make the grooves functional.
In any case, in about a month or so depending how long it takes for my 3tech head to arrive, I should be able to put the "grooves in a G10" thing to rest... :) I have a camera too so you guys can see what it looks like.
Jeremiah
55 MPG daily driver
PostPosted: Fri Apr 28, 2006 5:15 pm
That tank was when I was doing my testing, so I wasn't easy on it. The next tank of normal driving and timing set is 45.6 MPG, will get an average of three, though. that's 7.6 MPG increase so far with the head and sproket.
I could definitely use a real ignition, and the cat is probably somewhat plugged. I will get around to all of that soon enough, though.
I'm hoping with a new exhaust W/ muffler & no cat, ignition, ram air and underdrive pulley i can break the 50 MPG mark.
PostPosted: Sat Apr 29, 2006 2:06 am
Cool. No matter what, I'd just like to see it done.
PostPosted: Mon May 08, 2006 9:06 pm
finally broke the 40 mark. 44.66mpg!!!!!!!!!! mixed driving
PostPosted: Sat Jun 17, 2006 10:21 am
My car is a 96 metro with 3cyl 5 spd.it is all stock.Now I am putting in a new motor.I got around 44 mpg with the old motor.I hope that the new one will get better.
PostPosted: Fri Sep 01, 2006 11:38 pm
Vehicle: 1988 Chevy Sprint, 5 speed, stock curb weight (rated at 48 MPG)
Mileage: 61.5 MPG (US) / 3.8 L per 100 kms
Conditions: The vehicle has seen a mix of city and highway driving, it started this tank of fuel with wrong spark plugs and stock timing, and part way through were replaced with correct spark plugs, and timing was bumped to 15°. Idle speed does need to be knocked down a bit though. 26 liters of Chevron 94 octane were used for a distance of 471 kms.
Driving Style: I get in the car and go. I don't put extreme effort towards economical driving. I keep the car in it's powerband and drive in the neighborhood of the speed limit. There are occasional spirited bursts with a moderate amount of coasting and engine braking.
Comments: I expect better mileage in the future now that the engine is running better and that I'm running more timing now. I got this level of efficiency without really trying. I'm genuinely suprised by this level of economy. With more effort it could be a lot better.
PostPosted: Sat Sep 02, 2006 4:16 pm
Lihtan wrote:
Driving Style: ...There are occasional spirited bursts with a moderate amount of coasting and engine braking.
I hear that.....sounds like me at times...spirited bursts. :lol:
92 Geo Metro HB
PostPosted: Sat Sep 02, 2006 6:30 pm
Just thinking, that i see several threads of these report you mpg, good idea, but unless I am missing it, I think we should create somkind of data table (ex. 1/4 mile), or better yet website database that we can post our MPG for our car and model etc, and make it searchable/browseable.
Ertman
PostPosted: Mon Sep 04, 2006 8:36 pm
Don't mean to rain on your parade, but is this calculated from the numbers shown on the receipt image you posted? If it is, you might want to double check.
... www.EcoModder.com
PostPosted: Tue Sep 05, 2006 2:42 am
There's more numbers on the back of the receipt too. "18.021877 kms/L", which is correct and "3.8246768 L/100 kms", which should actually be 5.54881153 L/100 kms. I think what happened is that I mistook the 18 kms/L for the actually amount of fuel purchased, and proceded to divide it by 4.71 (which would normally give a correct L/100kms answer). I should know better than do math while I'm driving. Plugging the raw numbers into Google results in 42.3900834 MPG. Thanks for pointing that out, the numbers seem a little more realistic.
PostPosted: Wed Sep 06, 2006 4:51 am
Vehicle: 1989 Forsa GLX, 5 speed, 4cyl F10 engine
Mileage: 26.2 MPG / 8.97 L per 100 km
Conditions: 40 degrees (celcius) ambient temperature. 12 km traffic road & about 20km highway, 88 octane fuel.
I guess nobody will get any worst mileage than me :( .
PostPosted: Wed Sep 06, 2006 5:23 am
pumashoes wrote:
...I guess nobody will get any worst mileage than me :( .
Don't bet on it. My GTi gets 24 MPG (10 L/100 kms). It's nearly impossible to drive it in a conservative manner. :wink:
PostPosted: Wed Sep 06, 2006 7:41 am
Consoling enough :D , by ignoring reality that it had a G13B engine :razz: .
PostPosted: Mon Sep 25, 2006 2:13 am
My 04 Geo has only been averaging 37mpg with moderate driving.
I haven't checked the timing or plugs yet, it is a new car to me and I am still getting in shape. I replaced a couple sensors and it is running well, but still has a check engine light on with the egr code.... I cleaned the
valve and passage once. It still smells like it is running rich too.
MM
PostPosted: Tue Sep 26, 2006 11:08 am
Ertman
There is a website http://www.gassavers.org where they maintain a database of fuel mileage. BTW I got 69 MPG on my last tank and my record is 72 MPG. If I use the air conditioning that drops to about 40 MPG. I have a 94 Geo Metro with wheels and tires off a 95 and a cam shaft from an XFi. I drive slow and do quite a bit of engine off coasting and a very light foot.
PostPosted: Tue Apr 03, 2007 2:36 am
This is TRUE and was calculated CORRECTLY.
My record gas mileage is 66.8MPG in a MK2 Sprint Turbo EFI, yes EFI
I slowly accelerated and didnt go over 110KM/hr at all. By the end, I had three litres left in my tank and I had gone total of 812KM, also, my tripometer is off by about .05% so every 1000km I have to add 50km to my tripometer, so around 850KM in one tank. My car is all stock no modifications at all, except for I have advanced my timing a little bit. I was driving in alberta so it is relatively flat, but there was still some long hills to climb. You just accelerate beforehand :P
PostPosted: Tue Apr 03, 2007 11:33 am
if your trip is .05% off then you should be adding 5km/1000, not 50
think:speak ratio = .8:1
 Post subject: I'm wrong?
PostPosted: Wed Apr 04, 2007 1:11 am
LoL. Actually, kid, if you do your math correctly... (take any calculator, times 0.05 by 1000) Voila! you will get 50!
If I was off by 0.005 (Which is called fiveTHOUSANDTHS) Then I would add 5km...
I suggest putting your think:speak ratio higher to something like 50:1, It might be good for ya ;)
"This is TRUE and was calculated CORRECTLY. " I'm not lying lol.
