It is currently Thu Oct 19, 2017 6:44 am
PostPosted: Tue Sep 20, 2005 6:44 pm
I havent seen anyone say anything about this, but was wondering... Has anyone tried mounting some aluminum panels under their car to try to clean up the areodynamics? I have just started toying with the idea and am gonna try finding a source for some thin gauge and mount under my car to give it a try. Any thoughts? Thanx.
[MOD EDIT] updated title
PostPosted: Tue Sep 20, 2005 9:46 pm
I've thought about it too, doesn't Lexus do something like that to their cars? Let us know how it goes. Maybe smaller mirrors and different front bumper might be easier and net similar results?
PostPosted: Tue Sep 20, 2005 9:48 pm
Tin/sheetmetal (comes in 12" ~ maybe 24/36" widths on a roll)?
Thicker?
Aluminium sheeting?
Hmm, methods of attachment:
Rivnuts (rivets with threaded nuts on the end, needs a "rivnut" gun..)
generic sheetmetal screws?
Some 90* angle screwed on here/there?
<img src="http://tellico.off-road.com/wwwthreads_uploads/1438321-lolsroyce.gif">
PostPosted: Tue Sep 20, 2005 9:52 pm
Seems with one of these
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=34104
You could make runners/dimples (whatever the "DENTS" are called in sheetmetal to give support/rigidity) or 90* bends to tuck up and under stuff.
PostPosted: Tue Sep 20, 2005 10:57 pm
the newer porsches all have covers that go under the engine bay to create a smooth bottom to the entire car (including the transmission tunnel), it definately works, BUT you'll probably see higher oil & water temps as you're restricting airflow in the engine compartment. rally suzuki said he had to install an oil cooler after fitting a skid plate just from the reduced airflow around the oil pan.
you'd probably find it more useful to first lower the car and install a LOW front air dam and side skirts. if you're on a budget, lawn edging from home depot works great.
eg.
Valley View
Professional Edging, 20 Ft.
Model PRO-20
PostPosted: Wed Sep 28, 2005 1:59 am
that's funny - i did the lawn edging dam/skirts thing to a rabbit i owned years ago. never could tell if it worked...
maybe that's because it didn't make an easily measurable difference.
if you're interested in some numbers for this sort of thing, honda measured the difference from adding more aerodynamic wheels and a decklid spoiler to their accord hybrid, compared to the non-hybrid car. these changes improved the coefficient of drag from .30 to .29
overall, the hybrid gets 7 mpg (US) better economy on the hwy than the non-hybrid.
the engineers attribute 5% of this 7 mpg improvement to the aerodynamic changes. 5% of 7 mpg is around 1/3 mpg US. (.35 mpg)
http://www.hondanews.com/CatID2131?mid=2004091746959&mime=asc
does this mean aerodynamic changes aren't worth the effort?
maybe not. they didn't try nearly as hard on the accord hybrid as they did with the insight, which has much more aerodynamic wheels, skirts on the rear wheel openings, and added underbody panels. it's claimed the insight is the most aerodynamic mass-produced car at the moment.
http://www.insightcentral.net/encyclopedia/enaero.html
... www.EcoModder.com
PostPosted: Wed Sep 28, 2005 8:15 am
okay, couldn't sleep last night.
so i did a bit more reading on honda's site about the aerodynamics of the insight.
they say the flat underbody <a href="http://www.hondanews.com/CatID2055?mid=20010221001329&mime=asc"><b>greatly</b> contributes to the Insight body's low coefficient of drag</a>.
(my emphasis)
too bad they don't define "greatly" in numbers like they did with the changes to the accord.
PostPosted: Wed Sep 28, 2005 10:42 am
ok, i really should be working.
i've "insighted" a metro in photoshop.
and i confidently predict (based on no hard evidence whatsoever) that the following aero mods will return at least a 4% improvement in highway fuel economy:
as shown (or not) in the "photo" below:
- car lowered 2.5 inches
- 2 inch front air dam and rocker panel skirts (lawn edging!)
- 3 inch dams ahead of each tire
- flat disc-style wheels/wheel covers
- rear wheel skirts
- underbody flat panels
- dual windshield wipers converted to single wiper, centrally mounted and parked vertically (argue about safety here)
and now back to work...
PostPosted: Wed Sep 28, 2005 10:46 am
good luck on your research.
let us know if it imrpove mpg very greatly.
sorry bout my bad english
PostPosted: Wed Sep 28, 2005 10:48 am
oh, i don't think i'm going to do all this!
i was just brainstorming.
PostPosted: Thu Sep 29, 2005 8:01 am
More ideas:
• replace side mirrors with something smaller (perhaps video cameras?)
• shave unneccesary protrusions (washer jets, radio antenna, door handles)
• smooth over unneccesary gaps (cowl vent, panel gaps)
• use NACA ducts where you need air inlets (instead of opening the window)
• chop out the overhang on the rear bumper (transition it to the undertray)
• do as Metropwr did, and fill in the extra holes in the front bumper
• ovalized tubular control arms
PostPosted: Thu Sep 29, 2005 8:56 am
here's a link to a guy who added a wing to a vw beetle and claims improved mileage of 5-8%
<a href="http://www.max-mpg.com/html/tech/main.htm">http://www.max-mpg.com/html/tech/main.htm</a>
then again, he points out the beetle is a fairly un-aerodynamic car to begin with.
PostPosted: Thu Sep 29, 2005 10:03 am
okay, so we've got lots of aero mod ideas, some easy, some uh, more challenging
the question is how to test these to find out if they work, without the benefit of a wind tunnel
i suppose you could make some mods and just watch fuel ecomony at subsequent fill-ups, but there are so many other variables in the time/distance to go through a tank of gas, the results will be masked/affected by other factors
we need more 'instant' readings.
one idea i had is a "coast down" test. e.g. drive at a steady 120 km/h on a deserted road and depress the clutch at a known point on the roadway. then record the spot where the car rolls to a stop. make aero modifications, repeat, record, etc.
do runs in both directions to average out grade & wind.
or use a stopwatch to measure the time it takes to coast down from 120 to, say 50 (i have read that aerodynamics come in to play around 50 km/h, so coasting below that may not tell you much).
this way you could test mods before investing a lot of effort in them (e.g. duct tape and cardboard underbody panels/wheel skirts before fabricating metal ones).
PostPosted: Thu Sep 29, 2005 11:16 pm
link to an article about a guy who seriously aero-modded his toyota tacoma pickup truck and improved his hwy mileage by 28%
<a href="http://www.evworld.com/view.cfm?section=article&storyid=870">http://www.evworld.com/view.cfm?section=article&storyid=870</a>
PostPosted: Fri Sep 30, 2005 10:59 am
I read the whole Toyota article include all the comments. And it really got me thinking. I had no idea that aerodynamics would be such a major contributor to improving the vehicle's efficiency (although with a brick of a truck anything would help).
About wind tunnel testing: aerodynamic properties are the same at any scale. An accurate miniature model of your car would test the same as the full size version. There's no reason you can't do testing with a home brew mini air tunnel or water tank. You can also do live aerodynamic studies right on your own vehicle using yarn and tape:
Aero Testing Part 1:
http://autospeed.drive.com.au/cms/A_1044/article.html
Aero Testing Part 2:
http://autospeed.drive.com.au/cms/A_1055/article.html
Aero Testing Part 3:
http://autospeed.drive.com.au/cms/A_1065/article.html
Aero Testing Part 4:
http://autospeed.drive.com.au/cms/A_1071/article.html
Aero Testing Part 5:
http://autospeed.drive.com.au/cms/A_1080/article.html
Modifiying Under-Car Airflow:
http://autospeed.drive.com.au/cms/A_2455/article.html
Silencing Wiper Wind Noise:
http://autospeed.drive.com.au/cms/A_2445/article.html
PostPosted: Sat Oct 01, 2005 10:26 pm
the single largest contributor to drag is frontal surface area. the suzuki variants have that pretty well knocked. the rear of the swift isn't bad either and the gt's little air spoiler works great. i added the mid wing to lizzie's gti and i think those make the rear even a bit more slippery.
i changed my verts' mirrors over to the swift flag style mirrors which are a little larger and not as swept as the us market metro mirrors. if you're going aero, try those out.
PostPosted: Mon Oct 03, 2005 12:41 pm
How about that rear hatch though? Think it would smooth out air flow to tear drop out the back end. I have a '94, so the rear hatch is much more vertical, so in theory turbulent.
I just switched to 145/12" new tires from 155/12". Although the nominal numbers are similar, the real measurements show the 145 to be way narrower and significantly shorter (and handle way worse).
I never noticed how tall the Mk4s were until hearing you talk about a 2.5" drop. I don't think the Mk3s can do that and still be practical.
Any thoughts on how to make wheel skirts work?
Anyone want to get extreme and narrow the rear track and sheet metal like the insight (an excellent aero design).
If underbody sheet metaling causes overheating, that should be easily fixed with some engine bay exaust ducts.
I have a single big wiper operating from the driver's side that does an adequite job. Tucking it under a cowl would be good... Or, rig it to be quick release/install and just keep it inside until you need it (more practical here in Southern Cal).
I've always toyed with the idea of pin cameras in place of mirrors, but only as an unecessary luxury item to sell to the local yuppies. Weight increases for the supporting equipment could easily wash the advantage of loosing mirrors. Can you invert the mirror to the inside corner of the car? Would increase your blind spot, but should still give you visibility. Probably law problems with this though.
Jay W
505/287 Dakota
PostPosted: Mon Oct 03, 2005 8:14 pm
You can keep the regular mirrors, just do some shopping around for a set with slightly slimmer profile.
I had a '94. From what I remember, they are already quite slender and cut well in the wind.
The wheel well idea isn't too bad. However, you may also get the same effect from simply installing a set of full moon wheel covers.
do a google for Autoenhance racing discs. They are the only place that I have found on the net that offers 12" trim rings and 12" racing discs(fullmoons)
[The full moon idea is just a little bit more drastic than the "aerodynamic" wheels on the Insight]
One last thing, I don't think that they are available in a 12" but do a search for "low rolling resistance tires"
PostPosted: Mon Oct 03, 2005 8:17 pm
There is also a body kit set on Ebay occasionally that would add some ground effects and essentially give the same effect as lowering.
The price on the body kit is really nice.
The kit also fits the Subaru Justy. So, if you can't find it on Ebay, just lok around on the net.
Cheers,
Jonathan
