It is currently Mon Oct 16, 2017 6:50 pm
Post new topic Reply to topic  [ 270 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 11  Next
PostPosted: Tue Sep 18, 2007 4:43 pm
Thanks Derrell. :D
Here is the part I got from Greg, cut down and welded in the left side.
I drilled out all the spot welds and sand blasted the parts.
On the right side the panel behind the door is not welded on, so I welded Gregs part off the car.
I think I may weld this part on the side off the car too.
Like this.
I welded the top of the door surround to the right side.
I drilled out the spot welds that hold the upper inner door surround.
What's this in here? :shock:
Lucky for me nobody was home :D
I can't tell you how many spot welds I've drilled out. Hundreds :blaaah:
I'm doing all the welding I can from the inside, so I don't have to grind them down. And you can't see my crappy welds.
john :D
PostPosted: Tue Sep 25, 2007 10:47 am
Right side.
Cleaned up.
Primed
1990 and 196x panels are different. :shock:
I can fix it.
Image :D
john :D :D
PostPosted: Tue Sep 25, 2007 2:37 pm
Darrell wrote:
That's a lot of good work! I've never seen this post before. Keep up the good work. Are you still interested in electric components? Will you make it a hybrid?
Hi Darrell, I want to make it a hybrid. I just need to get it drivable first.
So I'm looking for electrical components.
john :D :D
PostPosted: Thu Sep 27, 2007 12:19 pm
Al welded up
MIG welded the right side B pillar in.
Also welded in the top of the door surround.
Well I'm up yo my limit of pictures again. :king:
john :D :D
PostPosted: Tue Oct 02, 2007 4:49 pm
Right side outer skin.
Ready to weld.
Fixed.
Welded in.
My crash dummy.
check out the t shirt. :D
I need to lower the seat.
Or lower my head. Image
I cut out the bulkhead.
That's it for now.
john :D :D
PostPosted: Wed Oct 03, 2007 8:54 pm
dang, ya got the same ratty 10 year old shirt
that's in my dresser........... :shock:
got mine as a 40th b-day gift
i really need to clean out that t shirt drawer :roll:
PostPosted: Tue Oct 09, 2007 10:58 am
Me too. :D
This weekends work.
Pushed it in the garage.
Can you see it?
There it is. :-P
Added more structural support.
That door will now close and lock.
I love making progress.
john :D :D
PostPosted: Wed Oct 10, 2007 9:40 am
FYI still reading, still watching, still enjoying your updates. Man, this is one big project for a little car!
... www.EcoModder.com
PostPosted: Wed Oct 31, 2007 3:27 pm
Thanks geometro, it sure is a big project. :mrgreen:
I haven't been able to work on it fore three weeks.
I've been remodeling the duplex.
:evil: :evil: Those slobs.Image
john
PostPosted: Mon Nov 26, 2007 3:00 pm
Here is a front view with a fortech wheel arch.
It needs to be 3 1/2 inch wider. Any suggestions?
john :D :D
PostPosted: Tue Nov 27, 2007 8:35 am
I like hearing myself type, motorcycle fenders? basically creating a sperate fender piece like old school cars?
PostPosted: Tue Nov 27, 2007 10:45 am
Yah, I bought some trailer fenders to try.
john :D :D
PostPosted: Wed Dec 05, 2007 11:06 am
Hi, the International hood was too short, so cut up a Buick hood.
It looks better in person. :clown:
I also got parts for the roof (thanks John Goolevitch!).
That's it for now.
john :D
PostPosted: Thu Dec 27, 2007 3:29 pm
Worked a little on fitting the roof.
John sent me the part that goes over the windshield. I still have to get it lined up.:razz:
The front gets cut off too. Image
All the roof parts in place (sort of). Looks nice. :D
Also, see the trailer fenders?
A fuzzy closeup of the fenders.
What do you think?
john :D
PostPosted: Fri Feb 01, 2008 1:27 am
johnsn!!!! wake up !!! it's 2008
we need an update :lol:
PostPosted: Mon Feb 04, 2008 11:08 am
:-P still remodeling the duplex :-P
But I will finish this month. Or die trying. :shock:
I'm so sick of that place!
john :D
PostPosted: Mon Feb 11, 2008 3:47 pm
When I got the doors they where rusty.
This is the left one.
So I removed the door skin.
Cut out the rust.
Tried to weld some holes.
Weld in patch panels.
While the door was apart I put in power a window.
I also took the door handle off.
john :D :D
PostPosted: Mon Feb 11, 2008 8:11 pm
glad to see you're back on the project
power windows on a fuel miser ? :lol:
if you get a chance check out coyote x's
vert project, a real lesson on rust removal 8)
PostPosted: Tue Feb 12, 2008 11:22 am
Well I did the door a long time ago. I just never posted it.
I never did power windows before. So I thought I'd try.
I've been following coyote x's vert project. WOW :shock: I like it.
Anyway, I'm still working on the duplex.
john :D :D
PostPosted: Tue Mar 18, 2008 9:01 pm
put down the power saw...... :evil:
step away from the duplex... :twisted:
think of your welder, it misses you.. :oops:
a small car has lost it's master..... :cry:
who will save it........ :huh:
PostPosted: Fri Mar 21, 2008 4:10 pm
I miss my welder too. :cry:
Almost done at the duplex. :alien:
Gotta get it rented. Money going the wrong way. :|
my wife is going to be gone next week. :wink:
So I'll do some work in the garage. 8)
john
I'll keep fixing it 'till it doesn't work
PostPosted: Sat Apr 05, 2008 11:12 pm
bump on this project very interesting
one structural concern for your safety though the rear end
there are allot of stress points
as indicated in red for the lower support
as indicated in red:stress points
yellow: direction of rear end possible catastrophic travel
green: possible way u shaped support bar can warp from extreme stress
blue & purple: possible ways to fix stress problems using current support
white:filled in area for blue support to eliminate any possibility for warping
most potential way to solve stress problems
brown:one possible fix by running support from rear end to firewall
black: tie rear into center support
not to offend you designed it very strong more than enough for diving but i doubt you would survive being rear ended above 20-30 mph without serious injury from the car "folding" in on the passenger compartment....just a thought though
keep up the good work
PostPosted: Tue Apr 08, 2008 2:56 pm
Thanks demonchild, I plan to put more stiffeners in after I finalize the seating position.
Does any one know why my pictures don't show up on this thread consistantly?
Sometimes they do and sometimes they don't. When I click on them they will pop up.
Also I am out of space to upload pictures. Again :mrgreen:
Time to go beg for space. :-P
john :) :)
PostPosted: Tue Apr 08, 2008 7:55 pm
john :) :)
host your photos on photobucket.com thats what i do then link 'em on here and other forums i chat on
PostPosted: Fri Apr 11, 2008 9:40 am
Here is a top view.
As you can see, any supports have to go around me. :razz:
john :) :)
