It is currently Fri Oct 20, 2017 2:33 am
Post new topic Reply to topic  [ 270 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 11  Next
PostPosted: Mon Feb 12, 2007 2:41 pm
Monday report
Image]
removed the back wheel and suspension.
added ring to hold back end up, and rotate it.
Image]
Look Ma no floor
Image]
floor welded in, from bottom
Image]
floor welded in, from top
Image]
seat and batteries trial fit
Image]
cut the frame, serial # on top
Image]
just the seat
Image]
divider/re-enforcement
PostPosted: Tue Feb 13, 2007 12:04 pm
Hi guys, had a good night last night. that little bit of stiffening in the backbone made a big difference. I need to remount the dash, make the seat mounting, and get a heater before I can finish the backbone.
Also I will fill the hole in the floor.
Image]
more re-enforcements to keep it from bending in the middle.
Image]
the start of running the backbone up to the front crosmember. took the hump out. now I need to patch the hole.
Image]
frame caped off.
PostPosted: Tue Feb 13, 2007 4:30 pm
Teamswift Street Pharmacist
you're working really fast man, hurry up, I wanna see the finished product ^^ ;)
I'M DRIVING A LADA NOW!!!
PostPosted: Wed Feb 14, 2007 11:23 am
It's going to start slowing down soon. When I start doing mechanical work.
Thanks for the encouragement.
john :D
PostPosted: Tue Feb 20, 2007 1:39 pm
Image]
Removed the old paint, cut the welds on the drivers side floor. The floor had a big wow in it. Etch primer makes it look much better. :D
Image]
Look on the right side of the picture (left floor) small wow. It was a big wow. Took several hours to fix.
Image]
Cut out the fire wall through the cross member Also patched the hump hole.
Image]
Image]
Made a stiffener.
Image]
welded the stiffener in. Now the backbone is connected to the crosmember.
Also sanded the paint off in preparation of putting toe board to sub-frame stiffener. :cheers: :D :D
PostPosted: Thu Feb 22, 2007 12:30 pm
Took it off the rotisserie last night. Need to finish welding the engine side of the firewall. Dropped the subframe out. Almost hit my foot. :shock:
Tonight I'll see if I can finish welding, and strip the paint off the firewall.
john :D
PostPosted: Fri Feb 23, 2007 12:08 pm
Finished welding the stiffener. started cleaning off the paint.
That paint stripper is nasty. But effective.
Image]
took it off the rotisserie, and removed the subframe
Image]
unfinished welding
Image]
welding done, paint stripped off
Image]
I can't get back far enough to get all of it in
PostPosted: Mon Feb 26, 2007 11:44 am
Stripping paint and priming, The worst is over. :D
Image]
used up one wire wheel
Image]
All sanded and ready to prime.
Image]
Pretty
Image]
Etch primer, and hanging from the rafters.
Image]
Turned upside down. Fuzzy view of the toe-board.
Image]
Still need to clean under the cowl.
Image]
Inside firewall upside down.
Image]
This is how it pivots at the back.
Image]
All cleaned up and etch primed. The primer is still wet.
Image]
Doesn't that look better?
Image]
Still need to clean under the dash.
Image]
Toe-board cleaned and primed.
Image]
Flipped it over. Now it's time to strip and prime the rest. :0P
I'm getting tired. I feel like I'll never get done!
john
PostPosted: Mon Feb 26, 2007 1:07 pm
John,
That's a really cool project. I've thought of doing something similar but easier like using an existing Metro, removing the rear suspension, and installing a motorcycle wheel in the rear. It would end up being an enclosed legal motorcycle in the state of Oregon.
Q (Bend)
PostPosted: Mon Feb 26, 2007 1:11 pm
Q wrote:
John,
Q (Bend)
id think that whould be kinda tippy unless you were going oto cut the car inhalf
PostPosted: Mon Feb 26, 2007 5:25 pm
geopat wrote:
Q wrote:
John,
Q (Bend)
What do you mean cut the car in half? Which way?
john :D
PostPosted: Mon Feb 26, 2007 7:53 pm
Wow. Cool project.
When I looked at the CAD drawings with the batteries, the first thing that came to mind was: will the suspension support them all?
What kind of range & speed are you aiming for in the EV version?
... www.EcoModder.com
PostPosted: Mon Feb 26, 2007 8:16 pm
geometro wrote:
Wow. Cool project.
Thanks,
The suspension will need to be beefed up a lot.
It's looking like I can't fit as many batteries as I would like to. :censor:
The original design was 60 mph, and 60 miles.
I live 30 miles from work.
Maybe when you get done with your cardboard batteries you can ship them to me. :rollin:
john :D
PostPosted: Mon Feb 26, 2007 8:21 pm
Sure thing!
I noticed you even drew the 3 cell caps on top like I did. Nice touch ;)
PostPosted: Tue Feb 27, 2007 11:14 am
geometro wrote:
Sure thing!
I copied you. :ez_tongue:
john :D
PostPosted: Wed Feb 28, 2007 6:42 pm
Q wrote:
John,
Q (Bend)
Check out this car.
http://www.3wheelers.com/projgal3.html
john :D
PostPosted: Fri Mar 02, 2007 12:34 pm
Image]
all cleaned up and etch primed. Subframe supports welded in and drilled.
Image]]
Rear floor trimmed to fit.set up with 150 watt lites to heat the metal. The paint stripper won't work at low temps.
Image]
Warm!
Image]
Paint stripping. Stinky!
Image]
Stripped and weld through primer.
Image]
All primed up.
Image]
Rear floor part welded.
Image]
Rear floor part welded from bottom.
Image]
Image]
PostPosted: Mon Mar 05, 2007 11:03 am
More stripping, welding, and priming.
Image]
A length of angle iron to get the floor straight, then weld the sides.
Image]
paint striped off the floor.
Image]
Etch primer
Image]
Inner sill striped easily.
Image]
Welded in inner sill.
Image]
Image]
:D
Etch primer,Looks nice.
Image]
:D
PostPosted: Tue Mar 06, 2007 11:32 am
How do you spell moc-up?
Image]
There is no clearance under the engine. I'll have to put a hatch in the floor. :-P
Image]
Image]
Maybe I should put a Sprint engine there. :D
PostPosted: Tue Mar 06, 2007 11:55 am
to answer your question, its mock-up :ez_tongue:
Project Page
Image Image
PostPosted: Tue Mar 06, 2007 12:07 pm
Thanks Matt.
john :D
PostPosted: Fri Mar 09, 2007 11:02 am
Well I cut a hole in my new floor. :shock:
I used 1/2" square tubing around the opening to stiffen the floor.
I also seamed sealed the firewall and sprayed sealer primer on it.
I think it looked better without the seam sealer.
But rust never sleeps. :furious:
That's all for now.
john :D
PostPosted: Tue Mar 13, 2007 4:13 pm
Didn't get much done this weekend. Had to work on the house. I'm putting in hardwood floors.
Image]
This picture was hard to take, I had the body tipped up and away from me. So I had to hold the camera up over the edge of the floor and click. Came out OK. This shows the mock-up Honda with more parts on it. It also shows the hole and the 1/2" square tubing.
Image]
Here s the bottom view of the hole , the tubing and the Honda.
PostPosted: Tue Mar 20, 2007 2:08 pm
I need to put a Swift engine in the front. to do this I have to modify the subframe to clear the transmission.
I have a sub-frame that is a little bent. So I will see if it will work.
Image]
Image]
The rear flanges didn't line up, so I cut them off.
See how short the rear flange is.
Image]
Image]
I thought I'd use 1" tubing to mount the subframe to the body.
Image]
This gap is wrong. It's too much at the bottom on this side.
Image]
Image]
Image]
Image]
So I cut it up.
Image]
Image]
And welded the seams. Image]
Image]
Image]
Image]
And trimmed, and welded a heavy walled tube on .......
The wrong way :shock: :furious: :censor: :thwack:
I'll fix it.
john :D :D
PostPosted: Mon Mar 26, 2007 11:13 am
Well I cut the top off the tube, and I'm starting to weld the subframe back together.
Image]
Image]
Image]
I won a spare bevel drive on eBay, and the guy I won it from lives really close to me. So when I went to get the part I also got a rear wheel with a good tire, and a Honda Silver-wing frame with the rear mono shock.
I cut the frame up and transferd the shock mounts to the cx500 frame.
Image]
here is the swing arm and a bucket of parts I cut off the Silverwing frame.
Image]
This is the shock mounts cut off the frame.
Image]
Image]
Image]
The shock mounts held in the correct relationship with scrap bits.
Image]
Image]
Image]
Image]
Image]
The shock mounts welded in. These pictures may look odd because when I took them the car was hanging upside down. So I flipped the pictures.
Now I have to put the swing arm back in and re-enfource the frame.
john :D :D
