It is currently Fri Oct 20, 2017 11:52 am
Post new topic Reply to topic  [ 270 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 11  Next
PostPosted: Fri Jun 22, 2007 11:10 am
johnsn,
What doesn't kill you only makes you stronger. Practice makes perfect.
Does that help any. :wink:
Sorry to hear about the troubles. I'm glad to see that you're slugging through it in any case.
PostPosted: Sat Jun 23, 2007 1:13 am
Voynik, Thank you for your kind words. It helps.
I cut the cowl off, and a big part of the firewall under it.
I welded up a bar that bolts to the front sub-frame bolts, and measured the door mounts.
The left door was 1/4" further back than the right. :shock:
It was also down a lot maybe a 1/2".
So I cut the hinge mount brackets off.
Then I welded the top one back on so it matched the left side.
I bolted the bottom bracket on the door, and bolted the door on the car with just the top hinge. Then I shimmed the back of the door to make it parallel to the left one. And welded the bottom hinge on.
I now have two doors the same front to back, and up and down.
That's all for now. My son finely came home so I can go to bed.
john :D
PostPosted: Sat Jun 23, 2007 7:49 am
Woohoo! Glad to hear things are working out and moving ahead again. I don't comment much, but I read your updates regularly.
... www.EcoModder.com
PostPosted: Sun Jun 24, 2007 9:32 pm
ImageImage Image Image Image
OK! I'm back on track. Got the right frame rail pulled up. Now it lines up with the left. I had to almost cut it off where it connects to the cowl and used a big turn buckle to pull it up.
I had to cut the floor away from the center stiffener all the way around it, and cut it from the Honda frame.
I'll post some pictures tomorrow.
john :D
BTW I'm officially behind schedule. =)
PS. Thank you geometro, I watch your project too. More Pictures please.
PostPosted: Mon Jun 25, 2007 11:17 am
Photos from this weekend.
Cut on red line.
Cut on red line.
Cut center stiffener. Also cut hight side diagonal stiffeners.
Cut frame rail loose, pulled it up, and welded it .
Frame straight.
Honda frame not straight... Yet. :wink: But it's vertical.
john :D
PostPosted: Wed Jun 27, 2007 10:21 am
I got the cowl level and you can see the curve in the A pillar is too high.
So I cut the cowl off the A pillar and slid the A pillar back down and welded it in position. Next I trimmed the cowl and tacked it to the b pillar.
I ordered a new cowl corner. The right one is not right.
john :D
 Post subject: Work
PostPosted: Wed Jun 27, 2007 12:55 pm
Your work is awesome! I was thinking of doing a project just like yours. I have a CX500 Custom and I was thinking of making a 3 wheeler using a front frame from a Geo. I was thinking of making it with a fiberglass body though. Your project has definately got me thinking! What kind of electric motor are you going to use? I think you could get away with an ADC 8" or a Netgain 8" DC motor and a Curtis or Alltrax controller. Where do you plan to put your batteries? You might want to consider them into your plan before you get to far. I would have thought you would have integrated your battery racks into your frame. That way their weight is down low and will help you with your CG. What kind of batteries will you use? Trojan T-145 perhaps? T-105 6V batteries? 120 volts is 20 6 volt batteries. They are HEAVY too. I think the last time I checked they were 50 pounds each! My 1990 Nissan 240SX electric has Hawker Genesis 26Ah batteries, 12V, each weighs 23 lbs. They are light but are crap for range.
PostPosted: Wed Jun 27, 2007 2:57 pm
jodydewey,
Thank you. Lots of questions :D
To start with, I'm going to get it running with a CX 500 engine.
Later on I'll convert to hybrid or all electric.
My electric motor is a ADC 8"
The batteries go in the front, beside the driver, and behind the driver.
I designed the frame so that Trojan 6V just fit beside the driver (me) :D .
My original calculations showed the batteries where 75% of the vehicle weight. 96V = 16 batteries @ 65pounds each =1040lbs. :shock:
I think my original estimate of the vehicle weight without batteries is high.
john :D
PostPosted: Thu Jun 28, 2007 2:53 pm
Worked on the L door and door frame.
Looks cool. see that empty space where the quarter panel meets the roof post? I need that part for both sides.
E-mail me if you have them.
john :D
PostPosted: Sat Jun 30, 2007 10:43 pm
Put the engine in today.
The engine went in OK, but I can see I will have to make the hole in the bottom bigger to get it out. Or make some other way to get it out. :shock:
Put the front sheet metal on. The cowl was about 1/2" short. Do I know what I'm doing? Guess not. =)
Let in new cowl corners and cut the front lip off the cowl. :evil: AGAIN :evil:
I think I may have to change its name from Sparky to Patches. :roll:
john :D
PostPosted: Mon Jul 02, 2007 11:21 am
Hi John,
the admins have finally blessed my account so I can post here.
I was going to ask you how you were going to put the engine in, but that's done already. Nice!
Just a few questions:
What kind of spot welder did you get and how do you like it? Worth it?
How are you going to attach the windshield?
Is your floor level?
Will your seat have a head rest to protect against neck injury /whiplash?
Tom.
PS:
For those of you following John's thread, I'm also building a hybrid-electric car, but it'll be a four wheeled car. I'm posting updates on gassavers.org:
http://www.gassavers.org/showthread.php?t=3070
PostPosted: Mon Jul 02, 2007 12:44 pm
tom_eberhard wrote:
Hi John,
Tom.
Tom, welcome to Team swift.
Answers.
I got my spot welder off ebay. I had to work on it to align the electrodes. It works good, and I like it a lot. It is very heavy and that makes it awkward. It is worth it. But I think I would just go down to Harbor Freight and get one on sale.
The windshield will go in using a standard rubber gasket.
The floor is supposed to be flat and level. :lol:
I will be putting a head rest on the roll bar.
Yesterday I tacked up the cowl.
I mocked up the front end sheet metal and saw the nose is to the left a little. More work. :wink:
john :D
PostPosted: Wed Jul 18, 2007 11:35 am
I've been on vacation. Now I'm back.
This is what it looks like now.
I built a tent so it's safe from the rain, and I'm safe from the sun and rain. :lol:
I'm working on the front panel now. I'm trying to get it straight. :ez_tongue:
john :D
PostPosted: Tue Jul 24, 2007 3:23 pm
I've been working on the hood.
I cut a chunk out of the middle. But I like the ridge in the center. So I'm trying to weld it in.
I'm also trying to make the hood follow the curve of the fender.
So I got a new tool (toy) :razz: .
They are a shrinker stretcher set from Harbor freight. About half the price of the set from Eastwood.
I really like it, it works so nice.
john :D
PostPosted: Mon Aug 06, 2007 3:03 pm
Hi, I got some more work done.
Welded in the door step and replaced the inner sill I had to cut out.
Welded in the B pillar and support post.
I clamped on the right quarter panel and started working on the rear sheet metal.
I'm using the hood off a 1941 International Harvester pickup.
Lots of room.
What do you think?
john :D
PostPosted: Mon Aug 13, 2007 2:59 pm
I'm going to trim the bottom of the hood at the green line and make it open here.
No comments from anyone?
john :)
PostPosted: Thu Aug 16, 2007 12:30 pm
I cut the hood side.
I made some sheet metal angle and used my shrinker to match the curve of the hood side.
Then I spot-welded them on.
john :D
PostPosted: Tue Aug 21, 2007 5:31 pm
It's on wheels! ImageImageImage
Now I need to get the front wheels pointing the same way.
I think I have the wrong rack. :huh:
Now back to ImageImage
john :D :D :D :D
PostPosted: Fri Aug 24, 2007 2:02 pm
It turns out the tierods on the rack I used are longer. So I cut them. :D
I made an adapter from the Mini rack to the Sprint steering.
And plugged in the steering.
It's too long. So I'm going to shorten it and make something to hang it from.
john :D :D
PostPosted: Sat Aug 25, 2007 5:19 pm
looks great! nice job, hope to see it done
vtek 4 life y0!
PostPosted: Mon Aug 27, 2007 2:28 pm
Thanks Vtek.
The wheels stick out a bit :shock: :razz: :mrgreen:
Got the steering mocked in place. Cut the column down to fit. Now if I can get someone to push ... :ez_wink::bump: :shock:
BTW that's a Chevy Sprint steering column and wheel.
john :D :D
PostPosted: Sat Sep 01, 2007 10:02 pm
Turned it around and put the rubber springs on with Hi-Lows set all the way low.
That's too high! :shock:
And the springs are way too stiff. I'l have to figure out how to soften them up. :thwack:
john :D :D
PostPosted: Fri Sep 07, 2007 7:43 pm
and you need rims with backset
lots and lots and lots of backset :lol: :lol: :lol:
keep up the good work
PostPosted: Wed Sep 12, 2007 2:15 pm
hillbilly 993, can you draw me a picture? :-P
I lowered the suspension about 2 inches. This is about where I want it.
Got the parts to finish the B pillars. All the way from England. Thank you Greg! :D
john :D :D
PostPosted: Fri Sep 14, 2007 3:29 pm
That's a lot of good work! I've never seen this post before. Keep up the good work. Are you still interested in electric components? Will you make it a hybrid?
:P
If we did the things we are capable of, we would astound ourselves. ~Thomas Edison
2000 Chevy Metro 1.3L
cron
