It is currently Sat Oct 21, 2017 8:27 pm
PostPosted: Wed Feb 13, 2008 11:41 pm
With 350K on my metro, my dad was saying that the shocks have never been replaced and they should be done. If I were to get new shocks, would the car place be able to lower the car at the same time ? How much should I ask for that will improve my economy :P thanks
PostPosted: Thu Feb 14, 2008 5:24 am
It can do nothing but help. When I lowered my cavalier I gained about 1mpg. My geo on the other hand is almost stock.
ETA: Must stop staring at that damn avatar. Image
-- Don --
The G10, Suzukis way of natural traction control.
This is my hooptie, there are many like it but this one is mine. With out my hooptie I am walking and without me my hooptie is broken down.
PostPosted: Thu Feb 14, 2008 9:27 am
Lowering is a well known way to slightly reduce both drag & frontal area.
Several luxo-barges automatically lower at highway speeds to save a small amount of fuel and/or go faster. The previous gen Lexus flagship claimed a Cd reduction of .01 by lowering 1 inch, if I'm not mistaken.
The results will be small, though. You probably won't be able to see the change in normal tank-to-tank monitoring, just because the normal variability most people experience there is larger than the small improvement in MPG..
... www.EcoModder.com
PostPosted: Mon Oct 13, 2008 3:57 pm
in the columb b, however, a car with a lower center of gravity will be more stable at speed and potentially you can do less braking as the car will drive more surely.
so in terms of nut-behind-the-wheel it may be better or helpful :)
though there is the downside of less visibility on the highway, which sucked in my slammed crx. despite it being YELLOW (i know, cursed), i still got side swiped by some old broad that "didnt see me"
I digress.
