It is currently Sat Oct 21, 2017 6:44 am
PostPosted: Thu May 15, 2008 11:51 am
Does anybody know what a 1994 Geo Metro XFI with A/C gets on MPG?
PostPosted: Thu May 15, 2008 6:54 pm
Not sure they came with A/C
PostPosted: Thu May 15, 2008 7:58 pm
Probably not an XFI if it has A/C unless it's some add-on unit.
Is it a 5 speed or auto?
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Fri May 16, 2008 3:15 pm
probably get around 5-6mpg less with AC on.
I get 45mpg on my 1.0 5spd, with AC off, and around 39mpg with AC on.
The ac compressor puts a real strain on the engine, and you can actually feel the compressor kick in and you loose a a little power.
White Vert : SOLD
Yellow Vert : SOLD
