It is currently Sat Oct 21, 2017 6:39 pm
PostPosted: Sun Jun 29, 2008 8:35 pm
Online
I used to have one of those really nostalgic vacuum gauges that read "Power" and "Economy", but the needle broke off and I had a hell of a time locating a replacement. The new gauge is a "Vacuum/Boost" gauge made by Sunpro, but the only scale I can use on a non-turbo vehicle will be the vacuum side of the gauge.
The new gauge required me to do a complete installation, so I decided to share it with you. The first thing I had to do is find a proper mounting location and on my car, the spot on the column was perfect for a 2" gauge. I simply used self tapping screws and secured the mount to the top half of the column cover...............
I then placed the gauge in the proper location and ran the vacuum tubing and electrical wires for the gauge illumination behind the cluster cover so nothing is exposed.
I simply removed the heater control cover plate and unplugged the bulb and spliced the illumination wires right into the harness so the gauge lights up when the cluster lights up.............
The mounting and illumination is now complete. The last thing to do is to run the vacuum hose provided with the gauge through the firewall to find a vacuum source. I ran a long screwdriver through the main wiring harness boot and fed the tubing through the gap made by the screwdriver.
I then adapted the connector to a vacuum source to monitor my fuel economy.
Here it is all installed...............
NOTE The vacuum line was spliced into the large vacuum line at the booster originally shown in the picture, however, this was causing poor readings. I later spliced into a vacuum source very close to the engine for instant readings of the engine vacuum. After driving with the gauge, it actually tells you when to shift if you know how to monitor it and will also make it easier to stay easy on the throttle.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Sun Jun 29, 2008 10:15 pm
Very nice.
A vacuum gauge is a welcome addition to any motor vehicle.
Is it in the way of the speedometer? :huh:
PostPosted: Sun Jun 29, 2008 10:32 pm
Online
Actually, when sitting in the normal driving position, nothing on the cluster is blocked except the odometer.
  • Project page
  • Build Video
PostPosted: Sun Jun 29, 2008 10:37 pm
I have never had a vacuum gauge on a car before what do you want it to show. Manifold vacuum or Port vacuum? A high or low reading? I am thinking of adding one have seen it come up on forums alot. And I checked out your build on ecomodders Mullet. Nice Job.
1991 Xfi "the most fun to drive"
2007 Civic Si
1983 F150 4x4
PostPosted: Sun Jun 29, 2008 10:57 pm
Online
The way mine operates is kinda weird, but I have it figured out and use it to save gas.
Starting the car, the gauge reads about 15 at idle and as you accelerate the vacuum drops and the gauge can read almost zero at hard acceleration. During upshifting, you can actually watch the needle slightly raise in vacuum right at the ideal shift point and it's pretty closely timed with the dashboard shift light. When letting off the gas, the gauge will read around 20-25 depending on speed.
Once you are up to normal driving speed, it's up to you to find the sweet spot. On my particular setup, I get the best fuel economy at around 55 MPH and the vacuum gauge reading around 10 on the dial. I try to keep it there steady. The gauge is sensitive and will change with throttle position/load. I use this to keep a steady throttle position to save fuel.
  • Project page
  • Build Video
PostPosted: Sun Aug 17, 2008 8:32 pm
Hey Johnny,
I figured I would throw a video on here of how to drive with it.
http://www.youtube.com/watch?v=9SM5Ory6QDE
2007 Civic Si
1983 F150 4x4
PostPosted: Sun Aug 17, 2008 8:59 pm
bbjsw10 wrote:
Hey Johnny,
this is a very poor video. i can hardly see what's going on , camera shakes and is low quality and blurry.
the vacuum guage how-to was good except the images are very small, blurry and it's hard to see what you acutally did in some areas.
PostPosted: Sun Aug 17, 2008 9:14 pm
bbjsw10 wrote:
Hey Johnny,
That's where I was thinking of putting my 'dream' gauge...where you put it in the video :wink: :wink: :wink:
I would like a combination tach/vacuum gauge that size with both needles on the same face, and some L.E.D.'s at the edge. The L.E.D.'s would have the green/yellow/red progression for both vacuum and rpm's.
Then, I could just tell someone: "Keep it in the green!"
It would be nice to be able to vary not only the intensity of the dial illumination, but also the L.E.D. lights.
At night, it'd be a cinch to see.
And for the racers :?: "Keep it in the RED" :D :D :D
PostPosted: Sun Aug 17, 2008 9:18 pm
1995Firefly4dr wrote:
bbjsw10 wrote:
Hey Johnny,
So sorry next time I will hire a filming crew for you. It is good enough to show basic concept.
2007 Civic Si
1983 F150 4x4
PostPosted: Sun Aug 17, 2008 9:43 pm
Online
I always resize my images to 500 pixels wide to make the images load better for those of us on a slow connection and also so it does not stretch the page out so the text has to side scroll to see. I could load up all my guides and How-to threads with 1280 resolution pics, but I prefer not to.
  • Project page
  • Build Video
PostPosted: Mon Aug 18, 2008 8:46 pm
in that case, it would be great to have your images hyperlinked to a higher-resolution version located in your album.
this is the code
Code:
[url=url][img]image[/img][/url]
