It is currently Tue Oct 17, 2017 8:07 am
PostPosted: Thu Jul 03, 2008 4:07 pm
1993 geo 3 cyl, 5 speed 4 door. after strolling thru the forums, I realize that my recently purchased car is not getting what it should. heres what new on the car.
new plugs wires, fuel filter, tires, exhaust,
Ive had the injector cleaned and serviced.
I am constanly running the AC. What gives to only get 30mpg and lower???
please help. ive already taken out the rear seat.
PostPosted: Thu Jul 03, 2008 4:28 pm
another thing, ive advaced my timing a little to comensate, but the idle level also goes way up. ive adjusted the idle screw in the intake but its all the way in. the advance timing really makes the engine rev alot! any help?
PostPosted: Thu Jul 03, 2008 7:19 pm
How many miles on the engine? Is the check engine light on? It may have low compression and low power which is common on these cars with the 1.0L engine. I would start with a compression test which will reveal a lot.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Fri Jul 04, 2008 12:17 pm
132k. no engine light.
PostPosted: Sun Jul 06, 2008 9:37 pm
Bad O2 sensor? Could be running rich, but with mileage that bad it should trigger a code.
Do you drive it really hard? Putting the pedal to the floor all the time will kill your mileage more than anything. Try driving speed-limitish for a week and see if it improves.
PostPosted: Mon Jul 07, 2008 12:10 am
Quick thought:
It depends on where you live, how you drive, what condition your engine is in, etc.
Even running the A/C, none of my cars get 30 mpg...esp a stick.
(For us to help you, we need more information.)
I suggest you fill out your profile, put a few shots of the beast in your album, and let some of the youngsters from Canada walk you through a repair.
They can spot reversed vacuum lines better than most.
PostPosted: Wed Jul 09, 2008 1:16 am
Perhaps a plugged coolant line to the throttle body (they look alot like a vacuum line). This would give you a high idle and very poor mileage.
1992 Convertable LSI
1991 Firefly
1989 Sprints (x2)
1990 Swift
1992 Swift
