It is currently Thu Oct 19, 2017 2:47 am
PostPosted: Fri Sep 05, 2008 12:17 am
map sensor?? egr???
any ideas. 94 xfi
1995 Eddie Bauer Exploder
1989 Suzuki Swift GTi (sold)
 Post subject: Re: 13 MPG!!!!! WTF!!
PostPosted: Fri Sep 05, 2008 6:53 am
Could literally be 100's of things, hard to tell without more information. It's not EGR though.
PostPosted: Fri Sep 05, 2008 1:43 pm
Check compression dry then wet
Any SES codes?
Tire pressure?
Outside temperatures?
Do you idle your car alot?
How do you drive?
Too many variables.....
94 XFI rust bucket
96 Honda Accord
PostPosted: Fri Sep 05, 2008 7:21 pm
Any SES codes?
Tire pressure?
How do you drive?
No codes. New O2 sensor, plugs, oil, etc. Even swapped out the TBI to see if that was the problem. Running so rich you can see and smell it. Runs like a raped ape, but is ultra rich.
PostPosted: Fri Sep 05, 2008 7:25 pm
Any SES codes?
Tire pressure?
How do you drive?
PostPosted: Fri Sep 05, 2008 7:31 pm
A friends geo storm was getting about 8mpg. it turned out to be the coolant temperature sensor
PostPosted: Fri Sep 05, 2008 7:32 pm
Ill check that 2nite
PostPosted: Thu Sep 11, 2008 9:09 am
Any results on this problem? I didn't think it was possible for a 1.0L to have that much fuel run through the engine. :shock:
Josh
"Always remember that in the equation for drag, velocity is squared."
1993 Geo Metro Hatchback
1996 Impala SS
1980 Yamaha Maxim 650
PostPosted: Thu Sep 11, 2008 9:53 am
Sad but True...
yeah wow I couldnt imagine mileage that low, how it could even run! hell I put alot of fuel through mine and bag it alot, it still gets above 30!
the lolcar family
PostPosted: Thu Sep 11, 2008 4:47 pm
Josh
Havent had time to mess with it yet, but I got a new coolant temp sensor and picked up a couple of MAP sensors on eBay. Also borrowed a compression tester just to check things out.
I'll let you know.
PostPosted: Mon Sep 22, 2008 10:49 am
Seems to have been the MAP sensor. Put a new one in and got most of my mileage back. Still need to do some work on it to get it back up in the mid 40 mpg range again. It threw a code this AM, so I need to plug the good ol diagnostic port and count some flashes I suppose.
Bill
PostPosted: Mon Sep 22, 2008 11:28 am
AND DAMN!!! Just remembered, in my quest to find a solution to my poor mileage, I swapperd the TBI from my '93 Lsi onto my '94 xfi. Wonder if that made a difference?
PostPosted: Mon Sep 22, 2008 11:36 am
Sad but True...
a difference how?
the lolcar family
PostPosted: Mon Sep 22, 2008 2:31 pm
XFI TB is smaller.....so I have been told. yet non-xfi's have been proven to get well over 55-60mpg with the "bigger" TB.
94 XFI rust bucket
96 Honda Accord
PostPosted: Mon Sep 22, 2008 3:00 pm
Sad but True...
ok... then what is he questioning is the problem then? if hes after mpg, and he got an xft tbi....?
the lolcar family
PostPosted: Mon Sep 22, 2008 9:59 pm
What I was saying is that my non-xfi tb is on my xfi motor right now. I may need to put the xfi one back on to get more mpg.
PostPosted: Mon Oct 27, 2008 5:54 pm
doubt there is any difference between the two, can you measure the
bore of the tbi's.......since you have both........?
Joe :)
