It is currently Sat Jan 20, 2018 2:19 pm
PostPosted: Mon Oct 13, 2008 9:52 am
How's it done? It's not something I've ever played with....is it as simple as twisting the dist? How is it measured?
92 Geo Metro Auto, 4 door, chick magnet
94 Geo Tracker sitting cut up in the back! Eventually dual T-cases, 33's, armor, stretched wheel base, solid axles and maybe even some road time someday!
03 Taco. 32" MT's 2.5" lift, Magnaflow exhaust, AFE intake, BBP roclk sliders, 12" sub, TRD L/S, pimp ride/tow rig.
PostPosted: Mon Oct 13, 2008 10:45 am
Must have a timing light, pretty cheap investment. Loosen 2 bolts holding the distributor to the head. With the engine running, watch the timing mark on the crank pulley while you slowly twist the distibutor. When you get it where you want it tighten the bolts and recheck the setting in case it has moved.
90 LSI 5 spd 3Tech Econo Cam 175/70/13s
PostPosted: Mon Oct 13, 2008 2:47 pm
Depending on the year you also have to jump the timing connector. There should be a pic under the hood of the jumper location.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Mon Oct 13, 2008 4:39 pm
Cool, thanks guys!
PostPosted: Wed Oct 15, 2008 7:27 am
Which way you twist the disty to advance the timing? Clockwise (looking down at it)?
PostPosted: Wed Oct 15, 2008 7:31 pm
Advance would be turning the top towards the windshield. Clockwise when looking at it from the driver's side.
  • Project page
  • Build Video
PostPosted: Thu Oct 16, 2008 6:15 am
It's weird. I've now turned it both ways, and have had similiar results. I just need to get a stupid timing light! Thanks for the info!
cron
