It is currently Tue Oct 17, 2017 2:21 pm
PostPosted: Sat Jan 24, 2009 10:48 pm
Here's a pic of Merle Showalter's 1984 patent on piston crowns. Pat# 4,471,734
Here's Smokey Yunicks 1984 patent on piston crowns. Pat# 4,467,752
One uses chopped lines, one uses little ramps, both accomplish the same goal. Apparently, there really is something to be had about mixing the charge well in the cylinder. Both claim more HP, reduced emissions, and increased mileage. My 2 cents is that we should pick up where they left off.
PostPosted: Sat Jan 24, 2009 11:10 pm
i wonder if someone made en engine with these pistons and as well 'singh' grooves.
PostPosted: Sat Jan 24, 2009 11:15 pm
I think the sing grooves accomplish the same thing, but only on a 1/4 of the cylinder. Picture the air fuel mix swirling around the outside of the cylinder, tripping over the slots or steps.
PostPosted: Mon Jan 26, 2009 12:25 pm
Merle's piston appears to greatly increase the quench area thus hurting FE and emissions. Smokey's looks like it might enhance the squish which would be a good thing.
1990 Metro G10 5-speed
Econo cam +8 degrees, Miata 14s
54 MPG
PostPosted: Sat Feb 14, 2009 1:18 pm
Thing about the Singh Grooves is that they are so easy to apply using a hacksaw blade and some swiss files.
Biggest change I noticed was an improvement in torque and the ability to let the motor drop to around 1500 rpm and pull away... in top gear.
I would though love to see the inside of a current F1, Indy Car, Nascar, MotoGP engine
TH
