It is currently Wed Oct 18, 2017 1:36 pm
 Post subject: My Airtabs test results
PostPosted: Fri Feb 06, 2009 6:31 am
I recently installed some Airtabs (Vortex Generators) to the rear hatch of my Metro. After 4 tanks of fuel, I did not see any increase in my fuel economy. These were basically designed for large vehicles like buses, RV's, and tractor/trailer combos......................
I do have one positive comment about installing these on the back of my car. They keep the rear window clean! Has anyone else tried using these on their vehicles? More info on the Airtab can be found on their official website........
http://www.airtab.com
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Mon Feb 09, 2009 12:07 am
Johnny,
How much highway driving do you do?
I was about to ask if these tabs cleaned up the air on the back of the car when I saw your second comment.
Any thoughts about fitting some on the bottom of the rear bumper?
Thanks
Trevor
PostPosted: Mon Feb 09, 2009 6:46 am
I do almost no highway driving. All my driving is mostly 55MPH country roads. I am not sure what putting the tabs on the lower part of the car would do.
  • Project page
  • Build Video
PostPosted: Mon Feb 09, 2009 8:28 am
keep the car straight in water? :lol:
keep on trying JohnnyTheExperimenterMullet. :yeahyeah :salute:
looking for:
PostPosted: Mon Feb 09, 2009 8:35 pm
"keep the car straight in water?"
Yeh Yeh smart ass
Have to ever looked at the lower rear of an F1 car or, a Toyota Prius for that matter?
What you see is called a diffuser
TH
PostPosted: Mon Feb 09, 2009 9:01 pm
Ideally you'd put them all the way around the back- top, bottom and both sides. Sides are probably more important since the car is wider than it is tall, but they would also look the worst.
1991 Geo Metro 2dr HB 1.0 Auto
PostPosted: Mon Feb 09, 2009 9:59 pm
I'm just glad the rear window stays clean :D
  • Project page
  • Build Video
PostPosted: Tue Feb 10, 2009 10:13 pm
Hmmm,
I have a friend who designed and patented something similar,(and certainly infringing) about 10 years ago.
You can make your own from the poly carb. corner protectors sold at home desperate to protect wall papared
corners. I have some on my F-100 truck on the front hood curve and the initial curve of the roof.
I picked up about 1mpg. at 70mph.
You make them by cutting off 2" sections of the plastic angle material and then cut the front vertical edge back at a 45degree angle so it forms an angled fin when set on a table. You then attach by using double sided stick foam tape
on the bottom surface.
You put them along the mid section of the hood or roof curve fanning outward at about 30 deg. from the centerline.
I will take a picture of the ones on my truck.
I think a deflector wing like the old station wagons used would be more effective on the rear of
the geo, but the VG's should have some effect.
Incidently, the home made VG's are exactly like the ones found on commercial aircraft and the shape
is probably more effective than these tabs, but the shape is more prone to hurting someone if they fly over your hood...
MM
PostPosted: Sat Feb 14, 2009 2:45 pm
I got the same results Mullet did after A-B-A testing the same vortex generators on two different vehicles. No improvement in fuel economy.
Tests were done on a 2006 Toyota Corolla 4 door sedan, and a 2005 Pontiac Montana minivan (most like the Metro's shape & Cd).
They will help keep a rear window cleaner though - tuft testing showed that.
No, the only thing I know of that you can stick on the back of a Metro and actually reduce fuel consumption is a partial Kammback. (Or a full boat tail, if you're feeling adventurous!)
EG:
(details)
... www.EcoModder.com
PostPosted: Sat Feb 14, 2009 8:15 pm
forgive me for sounding developmentally delayed, but I was looking at a few pics of cars with factory installed vortex generators (such as the EVO MR) and noticed that they have the pointy end aimed forward where you have yours aimed the opposite way.
Just a thought.
1995 Eddie Bauer Exploder
1989 Suzuki Swift GTi (sold)
PostPosted: Sat Feb 14, 2009 8:18 pm
MM
LMAO :rollin:
PostPosted: Sat Feb 14, 2009 8:36 pm
I also have seen then on some vehicles and yes the pointed end is foward and as they get toward the end of the vehicle the angle changes from straight foward to flared to the outside....
PostPosted: Sat Feb 14, 2009 11:45 pm
OEM Evo VG's:
(Sorry for it being a gigantic pic)
Pointy end looks more toward the rear to me.
PostPosted: Sun Feb 15, 2009 12:02 am
I wonder what a difference it would make to turn JohnnyMullet's air tabs around
PostPosted: Mon Feb 16, 2009 9:46 am
They're installed following the manufacturer's instructions.
VG's are no magic bullet, yet they seem to get a disproportionate amount of attention.
Real gains are to be found elsewhere.
PostPosted: Mon Feb 16, 2009 1:01 pm
You can download a Mitsu engineering white paper discussing the Evo factory VG's to discover that all they were tryng to accomplish was to bend the overall airflow hardly one inch to get better down force on the factory rear spoiler for running at 150 mph. They got some tiny amount of increased downforce like .01 whatthefuckevers that was just enough to stabilize the ass end at top speed only. And this little privelage cost the buying public $1000 USD, but really makes the speedbump to speedbump shopping mall ricers "feel fast".
The airtabs Mullet used are for 18 wheelers and are supposed to be installed "backwards" and the windtunnel smoke testing shows a shocking amount of smoothing out of exiting airflow off the rear of large box shaped objects (as in tractor TRAILER or Winnebago). It's a lot easier for long haul truckers to quantitatively determine a 4% increase in gas mileage and save a couple grand a year doing it. I could buy a couple geos for that kind of money....
I'm gonna stick the airtabs on every car & SUV I own just to keep the back windows clean. I may even experiment with displacing airflow around front truck mirrors to see if I can't get the whooshing noise to go away.
Rock On Mullet Man!
1990 Suburban 1500 5.3
2006 Trailblazer SS LS2
1965 Corvair Corsa 4-5-6 (4 whl disc, 5 speeds, 6 injectors)
1997 "Geo Cultus" MPFI going on this week, dogs....
F/S 3Tech economy cam
F/S 90 Metro hatch
F/S 89 Swift GTi body only
F/S 92 Tracker 2 dr rwd stock
PostPosted: Mon Feb 16, 2009 2:35 pm
well you can go over after dark and try. :lol:
Where can we buy these Klingon Nipples? :alien:
looking for:
PostPosted: Tue Feb 17, 2009 12:24 am
Long drive from Alaska.... then again I haven't been through Ashtabula County in a few years!!
