It is currently Thu Oct 19, 2017 7:53 am
PostPosted: Sun Apr 19, 2009 12:48 am
Guys check my DIY mods
http://www.suzuki-forums.com/suzuki-est ... post165604
PostPosted: Sun Apr 19, 2009 10:48 am
Mr Fit,
I sincerely would like to see your mods but I'm not going to join another forum in order to do so.......
Please post them here.
TH
PostPosted: Sun Apr 19, 2009 11:18 am
not joining another forum to see pics.
dont get me started on drilled front rotors :roll:
PostPosted: Sun Apr 19, 2009 11:24 am
please put your pics in your Album
:D
looking for:
PostPosted: Mon Apr 20, 2009 12:15 pm
:D
What he said... :)
PostPosted: Tue Apr 21, 2009 6:22 am
here are the pictures
PostPosted: Tue Apr 21, 2009 6:44 am
more pix of side gapping the plugs with tools used.
PostPosted: Tue Apr 21, 2009 7:04 am
more pix coming soon
PostPosted: Tue Apr 21, 2009 4:24 pm
if the pictures are more with all the text throughout them...don't bother. You can't see any detail.
PostPosted: Wed Apr 22, 2009 1:33 am
nice car. you have spent a lot of time. very thorough insulation.
what is the small forked tool used for?
does the catch can have a drain valve?
does it collect much oil?
why is the ground short on the spark plug?
looking for:
PostPosted: Fri Apr 24, 2009 10:39 pm
I believe it is cut to reduce the affect it has on the flame front from the spark?
He said it allowed for a smoother idle?
I always wondered about the interference if any. This is a similar to my questions was about indexing the plugs. but others here said it would make no real difference. I also would think that cutting the electrode could create other problems.
PostPosted: Tue Apr 28, 2009 7:14 am
thanks sir
it is for bending the cut up ground electrode to reset the plug gap
yes it has one below it
20 - 25 ml in a months time - i drain it out by the stop cock installed below it
to give a better exposure to the flame front
thx
PostPosted: Tue Apr 28, 2009 8:29 pm
thank you for answering all my questions. :D
i would think:
1. the plug life will be much shorter. How long do they last?
2. the average car does not need indexing or other measures, but turbos and high compression engines may benefit.
looking for:
PostPosted: Tue Apr 28, 2009 8:38 pm
When I got My 3 cyl Metro there was 2cc of oil in the air cleaner so i replaced the PCV valve and add a catch can. It expelled no oil in 3 months into a catch can so i removed it.
I salute your excellent heat shields. Have you measured before and after temperatures?
On my metro there was no difference in temp in the fender and at the air cleaner.
But your approach may be useful on my GT. I will take measurements when i get it running.
looking for:
