It is currently Sat Oct 21, 2017 8:44 pm
 Post subject: cat cut out
PostPosted: Tue Jun 09, 2009 12:07 am
If I happened to cut out my cat, would that riun my backpressure, and therefor make my gasmileage worse?
answer asap please!
any input useful :)
also wanna throw a gigantic cannon on it.
the looks i get......
 Post subject: Re: cat cut out
PostPosted: Tue Jun 09, 2009 4:40 pm
If I happened to cut out my cat, would that ruin my back pressure, and therefor make my gas mileage worse?
It would not ruin your back pressure and should not affect your gas mileage if you don't have an O2 sensor down stream of the Cat. You don't list your year and make car. My '91 has one O2 sensor, now located between the header and Cat. and I have an flow through Catco Cat. and glass pack so my back pressure is reduced greatly but it doesn't lack for power and I still got 52 average mpg on vacation with the Wife and stuff. If you have two O2 sensors and they read the same current the CEL will come on. The question will be passing emissions if a Cat. is required in Mn.
Have fun,
Bad Bent
PostPosted: Tue Jun 09, 2009 5:16 pm
I rode in a members stock GT Sunday and it was FASTTTTTTTTTTTTTT.
No Cat.
He said the Cat made it noticeably slower.
But does your car have to pass emissions testing?
looking for:
PostPosted: Tue Jun 09, 2009 5:36 pm
Backpressure? WTF mang. Plz don't say that word anymore.
1995 Suzuki Swift
SOHC 8V G13B, rebuilt with .020" oversize pistons, decked block ~ 9.8:1 comp, mild head porting, same old worn out camshaft, 2" cat-back w/cherry babomb, factory CAI modd3d with spray paint cap, urethane motor mount, TT front chassis brace, gutted rear interior, Razo RA25 shifty knobbzor, extra seat belts, H&R springs, '86 Maxima wheels with 195/55/15 Dunlop SP Sports.
PostPosted: Tue Jun 09, 2009 9:19 pm
Lose the cat :wink:
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Tue Jun 09, 2009 9:30 pm
well i have yet to cu tit out, but i put the cannon on, and iseems noticably faster, not i huge change, but pretty good.
Ill have to cut out the cat later due to rain.
PostPosted: Wed Jun 10, 2009 7:39 am
Hooray! Bring acid rain back!!
"Apollo 13", 436,600km | 89 Swift GTi -dead-
91 Pontiac Firefly.
