It is currently Thu Oct 19, 2017 2:37 am
PostPosted: Wed Jan 13, 2010 10:22 am
I found a Geo Metro engine on craigslist. I found out it was from a '91 XFI and I went to get it. I got the engine, transmission, axles, radiator, ECU, fuel tank and a bunch of various little parts. All for $100!!! I have yet to verify if it really is an XFI, but I'm happy either way for the price.
It's supposed to be a good running engine, but I haven't heard it run. I was going to rebuild my late '94 engine, but now I'm not sure. I could rebuild the XFI engine or rebuild the non-XFI engine and just stick the XFI cam in it. Anybody know if the XFI piston rings are the same as the normal engine's top rings? Or is it a special design? They are the same size in the service manual.
1992 Swift - Parts car (gone)
1991 Swift - Parts car (gone)
1990 Swift - Parts car
1997 Metro - Parts car (gone)
1993 Metro - Parts car
1989 Swift GTi - Parts car
1998 Metro - Parts car
PostPosted: Thu Jan 14, 2010 7:28 am
Same rings, just leave one off.
PostPosted: Thu Jan 14, 2010 9:00 am
WRONG on the rings. The rings on a Xfi motor are very, very expensive "no-gap" rings, just ask any Nascar engine builder. Between the rings, cam and transmission these are the main parts to a Xfi being so fuel efficent. The ECU, high temp thermostat, missing RH mirror, all help in making the Xfi so fuel efficent.
PostPosted: Fri Jan 15, 2010 12:22 am
Turns out it's a '92 XFI, not a '91. I haven't pulled the head yet, but it's definitely an XFI camshaft. Are the XFI rings still available?
PostPosted: Sun Jan 17, 2010 8:07 am
My 89 had a regular, no different from any other I've seen, ring on it. Bought new from the dealer, rebuilt four years later at 160K miles.
PostPosted: Wed Jan 20, 2010 1:16 am
I haven't seen what rings are in this engine yet, but I found this in the service manual.
http://i48.tinypic.com/2v8sh3s.jpg
PostPosted: Wed Jan 27, 2010 6:55 am
XFI piston:
XFI piston ring:
It might be hard to tell from the pic, but the staggered gap is also angled. I haven't checked if the gap is within spec yet. If it is, I might reuse them with new oil rings. Is that a bad idea?
And another craigslist score, engine stand for $10! :D
PostPosted: Wed Jan 27, 2010 7:25 am
Gasoline Fumes wrote:
A little offtopic regarding this pic... :oops:
Why do you need to measure ring gap 120mm in depth of the cylinder? :ez_roll:
......................................................................Suzy.....
PostPosted: Sun Jan 31, 2010 10:05 am
I don't know, that's just for the XFi engine. The standard engine is measured right at the top of the cylinder. :huh:
PostPosted: Sun Jan 31, 2010 10:50 pm
....always measured my ring(s)gap half-way down the hole....
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
