It is currently Sat Oct 21, 2017 1:04 pm
 Post subject: head shave or block ?
PostPosted: Fri Jun 11, 2010 9:07 pm
I was thinking of rebuilding my engine and instead of shaving the head I have thought about decking or shaving the block. Thusly getting a better quench to the head/chamber. Does anyone know what the clearance is between the head and pistons top factory? And what side do you guys think would be best for economy to shave from?
PostPosted: Mon Oct 18, 2010 7:58 am
Shoot for about .035" quench distance.
If you're overhauling the engine, then it's a no-brainer: measure where the pistons are at TDC in relation to the block deck before you final-assemble (yeah, this means you've got to mock up at least one cyl and the crank). The manufacturer should be able to give you the compressed thickness of the gasket.
Then you'll know how much to cut and from where. Any other method is just keyboard jockey stuff. Guys who build the engines tend to cut the decks and size the bores AFTER all the parts are in hand... 'cause those bits all can fall on one side or other of a nominal spec.
Is it a hassle? Hell yeah. It's a big part of why one 350 chev will sell for $1500, complete w/ parts, and another will have a $2000 shop bill for just machine work. If you want it really done right, it's a bit of work. Sorry I don't have the magic bullet for ya'.
-Bill
PostPosted: Mon Oct 18, 2010 8:00 am
Oh, and I forgot, I'd recommend throwing a degree wheel on and degreeing that cam, too. Esp. when whacking material off the heads and/or block deck.
-Bill
PostPosted: Mon Oct 18, 2010 2:54 pm
The pistons are zero deck height.
You don't say what motor you have, so I can't make a recommendation.
PostPosted: Thu May 12, 2011 9:55 am
1.0
PostPosted: Mon May 23, 2011 9:10 pm
I took .030 off the deck and unshrouded around the valves, when I went to order my valves out of california today they said some guy our od Canada made a big order of SS valves huh wonder who that was :huh:
PostPosted: Mon May 23, 2011 10:48 pm
So, does the piston stick up out of the block 0.030" now? Is it not going to smash into the head?
PostPosted: Tue May 24, 2011 7:33 am
No cause the head gasket is around .055 when compressed I would say it will crush to .045 giving around .015 between head and piston. This creates a little wedge effect and makes it less prone to detination.
PostPosted: Sat Jun 04, 2011 11:44 am
Have the XFI trans going on today and new clutch should be al together this weekend just waiting on my regrind cam to com back from DELTA cams some time this week I would think. WOOT can't wait. yes the piston was .030 out the hole and the old head gasket measured out to .055 so I should have .015 left should be awesome wedge effect and CR. :D
