It is currently Wed Feb 21, 2018 8:39 am
 Post subject: eco cam
PostPosted: Tue Aug 31, 2010 12:10 pm
Hi, im sure this has been posted many times so I apolagize but I can not find the info.
I am building a G10. Stock but the cam will be a eco cam from 3Tech.
I remember reading that it is recomended that a 10* cam advance be used.
Any opinions on this would be helpful, thanks
SCIENCE IS A WAY OF THINKING...Carl Sagan
 Post subject: Re: eco cam
PostPosted: Tue Aug 31, 2010 4:50 pm
I used the econo cam with the 10 degree gear on my 98 Metro and could not be more satisfied. All depends on how you drive it. If you drive at high RPM's, just get the gear. If you shift at low RPM's and want to save fuel, get both.
  • Project page
  • Build Video
  • Modified Suzuki 1.0L Engine
PostPosted: Tue Aug 31, 2010 11:54 pm
I agree with John, I am happy with my +10 gear and economy cam.
PostPosted: Wed Sep 01, 2010 1:24 am
thx, I jus may go with the advance. I'm guessing below 35k is low rpm range on these engines.
I drv lot of hwy n try to keep as low spd/rpm as I can stand. auto, no tach... 55-60 mph :cry:
I lov 5spds but I need my morning coffee more :wink:
PostPosted: Wed Sep 01, 2010 11:01 pm
I have an auto as well and I'm about to finish my first tank with an XFI and +4 gear, which is roughly equivalent to and econo cam with a +10 gear. So far it looks like if you do a lot of highway driving you'll want to keep the stock cam. I'm turning 3500+ RPM at 60 MPH and I think the smaller cam puts the sweet spot well below that RPM range. I was running a +10 gear with the stock cam before and it looks like it was better (for MPG) above about 50 MPH for me (2900+ RPM or so).
The smaller cam at +4 FEELS great, lots more low end and drive-ability so I'm going to try it w/o the advance, which will still be +6 because it is an XFI cam, and see if the higher speed MPG picks back up...3 gears just isn't enough with these cars.
1991 Geo Metro 2dr HB 1.0 Auto
PostPosted: Thu Sep 02, 2010 8:50 am
If you drive a lot of highway...buy a 5 speed. Fuel savings will pay for the coffee.
PostPosted: Thu Sep 02, 2010 11:31 am
Hi jake, then i'd hav ta buy a coffee holder too ! :wink:
I likes ta old me coffee in me and, ta drive a stick I needs a terd and. :D
PostPosted: Thu Sep 02, 2010 11:38 am
thanks for your info robertwb70, good stuff, I may try stock then just the eco cam then the eco cam with 10*
Glad it ain't a pushrod engine :vibe:
PostPosted: Thu Sep 02, 2010 12:05 pm
Don't worry about an ECO cam, you can't use it at those speeds. :)
You may actually be able to use a performance cam though...
