It is currently Thu Oct 19, 2017 12:40 pm
 Post subject: oxygen sensor
PostPosted: Mon Sep 06, 2010 11:32 am
can anyone tell me what the downstream oxygen sensor does, friend at work had his deleated on his pickup build. i would assume that it tells the computor if the converter is working and would have no other effect on the running of the engine, but i have been wrong before.
 Post subject: Re: oxygen sensor
PostPosted: Mon Sep 06, 2010 10:43 pm
That's all I've heard it does (monitor the cat to make sure it's still working)
- MPGuino
PostPosted: Wed Sep 22, 2010 2:37 pm
Yes, but if it doesn't function properly, the computer will not go in closed loop, instead it will sit in open loop, and you'll get less power and worse fuel economy.
My cars:
