It is currently Sun Oct 22, 2017 2:27 am
 Post subject: grt wht north/mpg
PostPosted: Mon Nov 01, 2010 11:04 am
Hiya fellers,
I get about a 30% drop in gas milage when it gets cold. :cry:
I go from 47 to 32mpg.
Any of you cold weather drivers get the same results?
Once I'm on the hwy I think the engine could be leaned out. I havn't looked into it yet but I am thinking of tricking the comp into thinking it is warmer by adding a switch and resistor to ground (if the pc measures by resistance).
SCIENCE IS A WAY OF THINKING...Carl Sagan
 Post subject: Re: grt wht north/mpg
PostPosted: Mon Nov 01, 2010 7:45 pm
don't take the temp sensors to chassis ground or you'll smoke the ecu. the sensors use a dedicated circuit with a return ground to the ecu.
PostPosted: Mon Nov 01, 2010 9:03 pm
Thanks again T3, I have a shop manual that should have the info I need.
I will post what I come up with...eventually. (I need a box full of round to-its)
