http://www.teamswift.net/
Fuel Injector Problems
http://www.teamswift.net/viewtopic.php?f=34&t=55501
Page 1 of 1
Author:  Swift101 [ Mon Feb 18, 2013 2:06 pm ]
Post subject:  Fuel Injector Problems
I'll start a the begining. I have a 91 Swift 1.3l tbi about 2 years ago i was playing around under the hood. while trying to check the state of the injector one of the hold down screws snaped of flush with the throttle body so i replaced with not know anything more than the fact that the metro had almost the same engine just missing a cyclinder so i took a throttle body from a metro.
Now the car run (just) but between 2000 and 3000 rpm if bogs down, If anyone would see it, it's like i have a bad turbo once it hits 3k it throws you back in the seat so my question is i'm now sure the Injector is the problem what i need to know is if the 1.0l injector is bigger or smaller then the 1.3l. i'm hopeing for bigger so i can just retune the car to use the fuel. I will also point out that aside for that the car runs fine (it only gets 23 mpg but thats beter than my mustang's 19 mpg) Any help in this matter will be.... well helpful.
Author:  bigdog6933 [ Mon Feb 25, 2013 12:17 am ]
Post subject:  Re: Fuel Injector Problems
Im not sure how to help with this, but my brothers Swift does something similar. Also wanted to say Hey, because my Brother and I are both Oklahoma TeamSwifters.
Author:  Swift101 [ Tue Mar 29, 2016 9:18 pm ]
casino online
I think I worked it out, have to run the car to check but they injector is a different size and from what I could gather its smaller.
Author:  tomcruzz [ Wed Mar 29, 2017 4:37 am ]
this is the best solution. thanks
casino online
http://www.phpbb.com/
