It is currently Fri Oct 20, 2017 12:06 pm
PostPosted: Sat Nov 21, 2015 1:09 pm
Could use a pair, ideally white or black, but mostly need driver side.
Ideally with copy of key so I can lock/unlock (I've got old replacement ones now).
Txt to 435 881 7590
Sean
PostPosted: Sat Nov 21, 2015 1:50 pm
I'd love to get a white passengers side handle....
PostPosted: Sat Nov 21, 2015 3:45 pm
look on ebay under 1992 geo metro 2door, same fitment, no lock cylinders (re-use old ones) only available in black-they need to be painted to match. :wink:
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Fri Nov 27, 2015 7:24 am
I have what u need in white and can make matching key or you can change out your cylinder. Many white body parts available. Let me know your needs.
PostPosted: Mon Mar 07, 2016 8:35 pm
If you have a mint unpainted white passengers exterior door handle I'd love it. My reason is that at the ass of the world we drive on the left and sit on the right and its that door handle that gets thrashed and eventually breaks. By getting a passengers handle from you guys it should be barely used.....
