It is currently Sun Jan 21, 2018 4:05 am
 Post subject: MK1 Turbo fuel tank
PostPosted: Fri Feb 26, 2016 10:04 am
Does anyone have a fuel tank in good condition from a '87-88 MK1 turbo that they'd be willing to part with? From what I'm reading, it looks like I will need to swap tanks and install an electric fuel pump if I pursue converting my NA Sprint to the factory EFI turbo setup.
 Post subject: Re: MK1 Turbo fuel tank
PostPosted: Fri Feb 26, 2016 1:15 pm
2 dr or 4dr N/A
just get a electric pump that will supply 28-32lb(to the rail)
with return line back to tank
PostPosted: Fri Feb 26, 2016 1:57 pm
Thanks, JV&S! My Sprint is an '87 2 door.
I was actually wondering whether I could get away with installing an electric pump without swapping tanks but I thought electric pumps needed to be installed inside the fuel tank to prevent the pump from overheating? Is there a particular fuel pump model that you would recommend purchasing? Thanks in advance!
PostPosted: Fri Feb 26, 2016 4:48 pm
a common external fuel pump to use is a bosch 044 fuel pump
Current car's, 2007 Suzuki SX4, 1993 Holden Barina / Suzuki Swift
Previous Car's, 2X Sigma's ( 85 and 87), 2000 Mirage, a 1987 Isuzu Bighorn (Holden Jackarooo), 2005 Lancer and a 2002 (MY03) Nimbus
Suzuki, The New Way Of Life
PostPosted: Sat Feb 27, 2016 9:37 am
Thanks, holden_swift. Have you or anyone used this pump on an unmodded T3? I looked at the specs and it looks like a great external pump from the reviews but I fear it would be way too powerful and cause drivability issues for a stock T3. Says it provides 72.5 psi for vehicles up to 650 bhp! Am I worrying for no reason?
