It is currently Sun Feb 18, 2018 5:03 pm
 Post subject: Wtb: 87-88 turbo pistons
PostPosted: Wed Jun 22, 2016 2:12 pm
Looking for set of 87-88 turbo pistons.
PostPosted: Wed Jun 22, 2016 3:59 pm
Turbo pistons are no longer available. You can buy aftermarket forged Pistons for $400+ per set. Or use g13bb (98-01 16v sohc) or g16b (75mm vitara pistons). They are around $100 on ebay.
PostPosted: Thu Jun 23, 2016 4:05 pm
I'm just looking for a used set. I started rebuilding a motor out of a 89 sprint for my 87 sprint and found that the pistons are different.
PostPosted: Thu Jun 23, 2016 5:01 pm
You can use them. They are on the smaller rods, but will easily take 15 psi if you're fueled and timed correctly
PostPosted: Fri Jun 24, 2016 6:23 pm
Are the turbo pistons forged or are they the same as the naturally aspirated pistons.
PostPosted: Fri Jun 24, 2016 7:46 pm
Same
