It is currently Wed Oct 18, 2017 7:09 am
 Post subject: I NEED A Mk4 ECU!!
PostPosted: Fri Dec 30, 2016 10:24 am
Hey Guys,
My swift ECU has bit the dust and curious if anyone has one they are willing to part with.
It is a F3 ECU from a 98 suzuki swift 5spd.
I am located in Ontario, Canada! Any help is greatly appreciated
 Post subject: Re: I NEED A Mk4 ECU!!
PostPosted: Fri Dec 30, 2016 3:49 pm
What motor is in your car? The f3 ecu is for a mk2 gt.
If you need I have a couple f3 ecus in bolton.
1994 suzuki sidekick 4 door
PostPosted: Sat Dec 31, 2016 12:49 pm
I have one out of a 98 Metro 1.3 5 spd.
Ken........
PostPosted: Tue Jan 03, 2017 12:30 pm
i was a little confused myself because the ecu says f3 however it is a different ecu than the f3 from my old gt (shape and colour)
my car has the 1.3L SOHC 16valve with the coilpacks on the side off the head not above the plug holes.
Reason for needing it is i am no longer getting a signal to injector 1 or 3 while cranking... have tried all new sensors and nothing has worked... timing is bang on as well!
PostPosted: Wed Jan 04, 2017 5:46 am
98 is MK5
I'm willing to bet it's not the PCM. The only ones I've ever seen go bad were jump started with backwards connections, and were DEAD.
