It is currently Sat Oct 21, 2017 9:31 am
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Sun Jul 16, 2006 4:48 pm
Where can I find a convertible top replacement with a zippered rear window over the web?
Pontiac Firefly 91 convertible
Converted In GT + turbo kit
PostPosted: Sun Jul 16, 2006 7:03 pm
http://cgi3.ebay.com/ebaymotors/ws/eBay ... d=best-man
you can also just type a.a.best co. into google and it'll give you the link to their web site. these is the business where tuffcarguy got his camel colored top with the tinted, zippered window.
color and material options, tinted and/ or zippered vinyl windows bring a premium price - over $200US plus shipping. a new standard, black EZ-ON top can be bought for around $180 if you locate a trim shop jobber locally.
PostPosted: Sun Jul 16, 2006 8:31 pm
thanks
PostPosted: Sat Jul 22, 2006 11:56 pm
The best top in my opinion looks the best. The heat sealed seam is hidden by the extra top material and looks more professional. :wink:
PostPosted: Sun Jul 23, 2006 11:18 am
please elaborate.
the last 2 tops i installed went on flawlessly. i don't have any leaks at the door and window seals and i can close the tops easily without having to stress the header.
best tops are considerably more expensive than the EZ-ON tops i've settled on. i figure that it's a replacement item like tires and that the life of a top is 5 years max, even for an expensive one. once the vinyl starts to stiffen up, it's time for a new one. a cooked, shrunken convertible top will damage the frame and break the plastic latch blocks. the hardened vinyl also causes frayed tensioning cables and damage to the cable pulleys.
when you add the cost of new hardware, adhesives, cables, and installation time to the cost of a deluxe, added feature top the cost per year goes up pretty quickly.
one last thing to add to the growing data base on vert tops. if the snap (mark 2) or plastic clasp (mark 3) on the strap that supports the floating bow above the rear window pops open when you put the top up, you're past due for a new top.
PostPosted: Fri Sep 29, 2006 10:27 am
T3 ragtop
Hooptie/TMD and I put a new top
on my 91 (blue vert)
I got off E bay from C.A.P out of cali
we got it on just have a couple of question maybe you could
Inlighten me this is my first top
We started at the front the top look like high quality
in the front it has like a pocket the front of the header peice
fit into like a glove so we rolled the edge of the top so the front seem is
just underneath the header edge glued it then moved to the back were
the top is screwed down with the hex screw the top has around the back
of the top a stirp of plastic sewn on it
is that pastic piece a gasket for the hex screw ??
is there any side to side adjustment ??
the whole top is so tight will it relax ??
just behind the door glass there is a hole were the top does not strech down far enough
just were you screw the stanless strip to it
it took both of us to latch the top
the top looks good
just to tight
thanks
.JV&S
PostPosted: Fri Sep 29, 2006 2:16 pm
T3 ragtop
fit into like a glove so we rolled the edge of the top so the front seem is just underneath the header edge glued it then moved to the back were
the front seam of the top should be rolled just slightly under the header. it sounds to me like you pulled too much material under in the front. there are little flaps on the sides that pull under the removeable steel panel that create a corner with the material sewn into the front seam. somethimes you have to stretch the vinyl 2 ways at once to make those corners on either side of the header.
the vinyl seal that is sewn to the back edge goes on the outside of the flange that is held down by the screws along the back edge.
the seal works with the flange, not the screws. the screws have little plastic washers under their heads that conform to the holes in the flange.
the side to side adjustment gets made as you pull the flange down tight. start with the center screws and work out as you pull the wrinkles out of the vinyl to each side.
the vinyl will shrink as time goes on. a new top should go up easily and the header should meet the top of the windshield and seat in the plastic alignment and latch blocks with one hand.
try to move the front seam right to the edge of the header panel. that seam should live just past the break point at the front of the header panel.
the top looks good
just to tight
there is a little bit of an arch that should be exposed in the corner just behind the side windows. there is a plastic wing just behind that arch that gets pulled down tight and and is held to the inner cowl with a plastic clip on each side.
did you find the holes in the flaps over the windows for the tensioning cables? the last 2 EZ-ON tops i've installed have had cross shaped slits for the cables on each side. that makes the tensioning cables pull the top's material down when the header flips forward into position. you might look for interference on those cables.
i'd start with pulling a little more material back away from the header. there's a little bit of a learning curve but it starts with getting the tools out and jumping right in. your next try will get this top straightened out. the next top you do will be perfect. :D
PostPosted: Fri Sep 29, 2006 3:47 pm
Thank for you help
ok i'll will let more out in the front
yes we found the slots the cable went through the dad showed me the push a welding rod through hole trick
the cable had were the pastic coting was rubed off
cable ok
missing one of the stanless gaurd on the wheel was missing so we made another out of stanless wire
we notice the 91 doesn't have the adjustment strap
that hooptie/TMD 92 vert has ??
yes found the little kiddney shape piece were you put the botton in secure it to the inside of inner quarter panels
Next time I do one ???
fun you should say that Read my new post
I'll let you know if I have any more problem with this top
PostPosted: Fri Sep 29, 2006 4:03 pm
post
PostPosted: Fri Sep 29, 2006 4:19 pm
the mk2 verts have a nylon strap with a snap on the floating bow over the rear window. the mk3 verts have a plastic cam type lock. i actually prefer the mk2 type, it's much more durable.
good job guys. :D
PostPosted: Fri Sep 29, 2006 9:16 pm
right back at ya thank's
Richard for the tuning info
like you said it looks good but
the next time will be better
-------JV&S------
PostPosted: Mon Sep 13, 2010 9:05 pm
Hell ya I'm jacking this thread..!
I can't believe it's been 4 yrs almost to date since my last top replace ment
Yummy Bacon came over today and we through a top on his ride yummy said he bought this off ebay with free shipping for $159. I wasn't into it been underweather for a couple of week but when he came over .....
How could I refuse .It's Yummy Bacon.!
BEFORE
AFTER
undu the rear trim piece in the back under trunk lid
unfasten side pieece behind both doors and the trim on the backside of each window
unhook top cable
unscrew front header
and roll old top to the front
THE IMFAMOUSE "JOHNSON " RODS
spray header with contact cement stretch top over front
re atach the header rail
put top on the have up position stretch top so you can put top under rear trim piece
rescrew the rear trim piece on ....reatach the side cables
scure the trim pieces behind the doors on the body
reatacch the molding bhind both windows on the top
..............................................JV&S
PostPosted: Mon Sep 13, 2010 10:05 pm
@ssclown
You are a good man Charlie Brown.Thanks for the hard work today.She is safe back in the Garage. I'm going to work on the bumpers tomorrow im going to pull the front off and sand it down and get it ready for paint.
Thanks Again
Yummybacon
PostPosted: Thu Jul 03, 2014 9:33 pm
and a Bump
PostPosted: Fri Jul 04, 2014 1:37 am
what do you think is the best top available for the geo
02 bmw 330ci zhp
'98 Chevy K2500
'76 Harley Davidson FXE
PostPosted: Fri Jul 04, 2014 7:58 am
this.
http://www.ebay.com/itm/geo-metro-Ponti ... 1183wt_664
PostPosted: Fri Jul 04, 2014 11:25 pm
you don't like the sail cloth
02 bmw 330ci zhp
'98 Chevy K2500
PostPosted: Sat Jul 05, 2014 8:55 am
for all practical purposes the stayfast cloth is sail cloth.
i have had this top on my red vert 2 years and it looks as good now as when i first installed it.
i don't think it will ever shrink like a pinpoint vinyl top.
PostPosted: Wed Jun 10, 2015 3:51 pm
JefferiySr this is your only warning - if you post one more embedded link like the ones i have had to strip out of your posts i will remove your ability to post altogether.
this is a suzuki swift and variant forum and you are posting in the metro vert section. this is not the place to discuss a mustang.
read the forum rules and straighten up. :evil:
PostPosted: Sat Jun 13, 2015 3:53 pm
and this knuckle head didn't listen. he posted yet another inane comment including not one, but 2 masked spam links.
just like jomo before him, he's history.
PostPosted: Tue Jun 14, 2016 1:55 pm
Replaced my top last week. Switch to tan due to the Florida summers are a bit hot. My phone app showing current "feels like temp 103 today. Purchased off of flee-bay for under $200.00. there was a 24 dollar up charge for color. Would give it a 9.5 out of 10 score. Upgraded to the second gen pulley wheel brackets I pulled from a junk yard a while back. See the different designs on the second pic. Have the side trim off, painting them with Plastic-Dip to help match the rubber trim.
PostPosted: Tue Jun 14, 2016 2:15 pm
speque, where are those pulley wheels used?
91 Metro Convertible, 5sp, Fed Emissions, no A/C
PostPosted: Tue Jun 14, 2016 2:35 pm
Yep. The bottom ones were my original ones. Note the cracks in the wheel. The others were pulled from a junkyard about a year or so. Didn't know there was different versions till I pulled them. Just like I didn't know there are at least 2 generations of corner window seals till last year. Unfortunately I only found one side and could loosen up the bolts to pull the frame part to match. :(
PostPosted: Tue Jun 14, 2016 7:55 pm
ya that is way nicer
good show
.Image
PostPosted: Wed Jun 15, 2016 12:58 pm
still not clear where they go, though
good show
cron
