It is currently Mon Jan 22, 2018 3:14 am
PostPosted: Mon Jun 23, 2014 12:31 pm
Hey all, can someone list, or point me to a list, brief, etc, to identify the parts needed to be pulled from a GTi for retrofitting rear disc brakes onto a vert? I've found a donor, but I'm not local to it, so I need to tell a puller what to grab.
thx,
brad
91 Metro Convertible, 5sp, Fed Emissions, no A/C
PostPosted: Mon Jun 23, 2014 4:38 pm
The knuckle an everything bolted to it and the brake line from the caliper back to the frame.
1994 suzuki sidekick 4 door
PostPosted: Mon Jun 23, 2014 8:04 pm
You'll need the emergency brake cables too.
Ken ...............
PostPosted: Mon Jun 23, 2014 8:57 pm
don't forget the gt proportioning valve off the firewall. :wink:
PostPosted: Mon Jun 23, 2014 9:19 pm
T3 You may be right, I installed a turbo from a Firefly in my vert (Vanilla Latte) and the original proportionning valve works great.
All wheels brake nice. I do have the valve from the GT in case. But for the past 4 years (summers), the braking is a delight.
Of course I handle Vanilla properly.
Less IS more.
PostPosted: Tue Jun 24, 2014 3:55 pm
frederick, i have also run the proportioning valve from a vert on the gt brake conversion. braking is good that way although i prefer the gt proportioning valve. the front end dives less under extreme braking.
also, you can actually adjust any of the proportioning valves to any percentage you like. they all seem to be the same unit, just adjusted differently and badged with a different color and part number sticker.
pull the stamped steel cover off and you will see the stem and lock nut. :wink:
