It is currently Fri Feb 23, 2018 9:38 am
Post new topic Reply to topic  [ 74 posts ]  Go to page 1, 2, 3  Next
 Post subject: My 1991 GT Build
PostPosted: Mon Sep 08, 2008 1:46 pm
title may be a little misleading, but ill explain why
its a 91 firefly, with a 91 gti parts car, aswell as my 90 t3. im going to mash all these cars together, to create 1 good one and throw the rest away (and sell whats left for cheap)
Im using my t3 motor that made 110whp@10psi with a rough tune, using a megasquirt n spark extra ecu, and using the gti body/interior/harness.
So we start with a bare shell and lots and lots of b-quiet sound deadener... in the pics ive used about 55-60sq feet already :shock:
im not going to use the gti rear brakes, although I was previously building a gti and it has new hubs/rotors/pads/ss lines, im planning on selling it, or using it on my 96 metro spec v swap. So im keeping drums for simplicity, bolt all the shit from the sprint to this car and replace the wearable items, so its getting new struts, bushings, front wheel bearings, brakes, balljoints/tie rods... everything basically.
this was the sprint, dyno day
wasnt too impressed, hoping the MS takes care of another 10+whp
not only am I swapping a megasquirt on this thing now, but im also fabbing up a 54mm throttle body from a nissan ca18de. it has the variable output the megasquirt will need, and it also has a built in WOT switch, which ill make use of in the future :D
Replacing the 2.25" straight through muffs sprint exhaust with a 2.75" with a real muffler on the back, and makin SOLID motor mounts out of hockey pucks! haha I saw it done once on here, I got some spares to try out. My poly filled ones arent tough enough
the lolcar family
 Post subject: Re: My 1991 GT Build
PostPosted: Mon Sep 08, 2008 9:04 pm
most of today was figuring out some body wiring, dickin around online, and cleaning the car. I used a whole bunch of degreaser and im not going to bother posting the DIRTY pic, but the engine bay is about 80% now, needs a little more cleaning, then some paint!
I also made some solid motor mounts, the stock ones I had poly filled were a noticeable improvement, but didnt stop my wheel hop issue, it felt better with the big cam shaking the whole car, so I cant wait to see what these solids are going to feel like!
Disassembled a bunch of the sprint today, got the whole harness out.
I also decided that my stock injectors at 210cc are too small... was going to rebuild some of my gti injectors at 270cc and use 3 of them on here, but im gonna use my supra 360's, might aswell.
tomorrow: paint engine bay and other accessories, more cleaning, put fenders on?, maybe mock up the cut for the new bumper. not having that shitty sprint bumper now, this ones lower, has fogs, and looks 10x better. no pics yet
the lolcar family
PostPosted: Thu Sep 11, 2008 12:24 pm
Looking gd mate keep us informed
How come u not using the G13B, is it because u had the T3 outta your car
PostPosted: Thu Sep 11, 2008 1:00 pm
I had and still do have a few g13b's sitting around, the drivetrain can only take so much abuse, so I went with what will get me 40+mpg and have upwards of 160whp. Remember my dyno was only 110whp with 10psi. Even with 14.7psi on a stock n/a motor (which I am running n/a rods and pistons for higher compression) I should have only netted 80-90whp. I cant wait to see what this thing can do with the megasquirt, 360cc's and 20psi
the lolcar family
PostPosted: Thu Sep 11, 2008 1:15 pm
guess ill add a few more pics, im being selective on the amount of pictures I post on here
this is how it looked after the cleaning was finished
this is one coat of tremclad gloss white
two....
and done
im happy with the way things turned out, and now that the paint has cured overnight, its time to mask off the white and paint everything I oversprayed on semi-gloss black
also, im pretty much ready to start installing stuff
my gr2s are going into the spring assembly, im using the h&r blue springs and im putting new wheel bearings in the front (did rears already and im taking those parts too)
the lolcar family
PostPosted: Sun Sep 14, 2008 1:31 pm
solid mounts ^
old mounts v
mandrel downpipe
I hate that car!
the lolcar family
PostPosted: Sun Sep 14, 2008 6:18 pm
the lolcar family
PostPosted: Wed Sep 17, 2008 10:05 pm
todays newest piece
the lolcar family
PostPosted: Thu Sep 18, 2008 11:10 am
Shes coming along great now engine bay is real set off with everything painted as it should
Whats next?? :D
PostPosted: Thu Sep 18, 2008 11:15 am
today I assemble front suspension is the plan
slowly coming...
the lolcar family
PostPosted: Thu Sep 18, 2008 11:42 am
what did u use to fill the shifter base?
HANSTECH
member of team
PostPosted: Thu Sep 18, 2008 12:01 pm
the shifter base that was filled came off of one of my parts cars that was modded. its just polyurethane, same stuff I fill motor mounts with
the lolcar family
PostPosted: Thu Sep 18, 2008 12:15 pm
it it easy to do? where can i get some?
HANSTECH
member of team
PostPosted: Thu Sep 18, 2008 12:25 pm
you should read up on how to do it
the lolcar family
PostPosted: Thu Sep 18, 2008 7:37 pm
Those pieces look like they are for windshield wipers as opposed to suspesion parts! At least compared to the last supension I worked on... Yikes! :o
Nowadays driving an 85 GMC SIERRA is painful... maybe thats why I'm currently working on an 87 Sprint Turbo!
PostPosted: Thu Sep 18, 2008 7:46 pm
?? what suspension parts??
the lolcar family
PostPosted: Fri Sep 19, 2008 12:26 am
sorry, steering, balljoints....
PostPosted: Fri Sep 19, 2008 3:04 pm
Haha, that's a shifter. He swapped out his shifter for a filled one.
Two strikes :P
PostPosted: Fri Sep 19, 2008 3:35 pm
lol yeah how did you think that was related to suspension??
the lolcar family
PostPosted: Fri Sep 19, 2008 4:24 pm
slowly coming...
I read it that way first... then I saw the pics were not of the suspension- :D
PostPosted: Mon Sep 22, 2008 3:04 pm
380cc
the lolcar family
PostPosted: Tue Sep 23, 2008 3:57 pm
my tank thats still half full of 94, and has my walbro 255 with only 8000km on it, had to take the tank!
just finishing up the wiring. this is where I am as of now, got some stuff to buy and hope to give her a first crank tomorrow!
the lolcar family
PostPosted: Wed Sep 24, 2008 7:55 pm
That's a nice steering wheel. :wink:
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Sun Sep 28, 2008 11:12 pm
didnt start, having problems with the vr pickup sending signal to the ms, if I dont get rpm signal I dont get fuel
the lolcar family
PostPosted: Tue Sep 30, 2008 2:04 pm
idling1
http://www.youtube.com/watch?v=HOC8hGpd5M0
idling2
http://www.youtube.com/watch?v=mdUshzXOUi0
no exhaust obviously
the lolcar family
cron
