It is currently Sat Oct 21, 2017 3:35 pm
Post new topic Reply to topic  [ 53 posts ]  Go to page 1, 2, 3  Next
 Post subject: My racing G13B engine
PostPosted: Mon Oct 06, 2008 8:34 am
This is my racing G13B engine which produce 160hp and 150Nm on STOCK PISTONS!
Lander
Suzuki Swift Kit Car
PostPosted: Mon Oct 06, 2008 8:38 am
Lander
PostPosted: Mon Oct 06, 2008 11:57 am
Hello Lander,
Nice setup, i like the tbs does are long tubes.
What kinda rpm are you looking for ?
9000 or 10000
G13B 1.3L 16v 115hp
PostPosted: Mon Oct 06, 2008 12:37 pm
ROV wrote:
Hello Lander,
9000 or 10000
Rev limiter is at 9000rpm, top torque is at 7500, hp at 8500
Lander
PostPosted: Mon Oct 06, 2008 2:16 pm
interesting, do you have a dyno sheet? id like to see how the power comes on.
is that 160whp or bhp?
the lolcar family
PostPosted: Mon Oct 06, 2008 2:56 pm
Sorry, no dynolist, my friend who build me my engine and also race swift in hillclimbing has that numbers. He has 165 hp (bhp, no whp) on stock pistons, he has little different intake system (8 stacks)
Lander
PostPosted: Tue Oct 07, 2008 3:27 am
Hi Lander,
Nice car, are you running on 13" wheels?
I see you are running a dizzy less system with twin waste spark systems.... well kind of.
How do you run that system?
Which ECU system are you using to be able to run that system?
Too many questions but if you can give me answer, it will be great.
Cheers
Atchi
PostPosted: Tue Oct 07, 2008 4:17 am
miniswift wrote:
Hi Lander,
Cheers
Atchi
Yeah, I am runing 13 inch wheels and using slicks from AVON, front is 9/20/13 and rear 8.2/20/13
I have racing ecu from Ignitech Czech Republic called Ignijet 2007. That ecu is using on racing bykes as well as twin waste spark system.
Lander
PostPosted: Tue Oct 07, 2008 6:59 am
This is an awesome car and engine! :worship:
ImageET 13.138 at 120.2mph
PostPosted: Tue Oct 07, 2008 7:25 am
Thank you. And that car is for sell. :-) Price 12500 EUR. I spend lots of more money in to it.
Next season I will race with formula F3 Dallara.
PostPosted: Tue Oct 07, 2008 9:05 am
Good luck with the sale and good luck with F3. Given all the development work sounds like a good deal.
PostPosted: Tue Oct 07, 2008 9:33 am
Hi Lander,
I thought Ignijet was for motorbikes.
Are they easy to use?
Is it like MegaSquart, reasonable cost?
Cheers
Atchi
PostPosted: Tue Oct 07, 2008 9:45 am
miniswift wrote:
Hi Lander,
Cheers
Atchi
Ignijet is original for motorbikes, but they modified it for us to be able to use on car engines (modification in firmware about crank wheel and crank sensor for crank timing)
Ignijet is much more better than megasquirt, with better spark timing.
I am thinking in future use Ignijet on my modified F3 engine. For now I have on it old Magneti Marelli MF3S ecu.
Lander
PostPosted: Tue Oct 07, 2008 2:55 pm
hello lander is your fuel pressure regulator any good i just bough the same 1 an the diaphram was torn!
i asking is it any good an how low & high can you adjust yours?
oh yes that video lander two words "midd evil" Sounds so sweet
Bong,Bong,Bong....zuki's
PostPosted: Tue Oct 07, 2008 2:57 pm
I set it to 3,4bar of fuel pressure and it works OK.
Lander
PostPosted: Tue Oct 07, 2008 3:53 pm
so 40-52 psi in that area?
do you still have the dogbox in that hellish beast?
PostPosted: Tue Oct 07, 2008 7:10 pm
Im wondering about your exhaust if there is any or what you have under there??
Thanks
PostPosted: Tue Oct 07, 2008 11:05 pm
Hi Lander
Awesome Swift. What kind of shocks does it have? and what weight of springs?
looking for:
PostPosted: Wed Oct 08, 2008 1:15 am
Hello Lander...
Your car is really admiring me.. I thot i can do the same like urs in Malaysia here... but hard to get parts and dun have really experts here.. and the cost i think very high to do that..
So, lander, what is ur suggestions and can u give me ur mechanical manual for me to upgrade my car just to beat vtec B20. Really appreciated it to get ur expertise.. :lol:
What i have now in my bonet is LSD street race cams, suzi sport race cams, stock pistons, suzi sport ecu, K&N ilter, oil catch tank, fuel regulator and SAFCII.. Last time I do port and polished but since no double valves springs then my valves crack.. now use stock head.. so, what is ur suggestion for me to upgrade.. and what is the best block of 1.6vitara to use for me to upgrade my the cylinders.. for pickup in 300 meters..?
Suzimonster
PostPosted: Wed Oct 08, 2008 6:42 am
suzimonster wrote:
Hello Lander...
Suzimonster
I am sure for 12,500 Euros you can get that manual. Expect it to come with the car! :lol:
This is no roadgoing vehicle. Suggest you do some searching on here and on redlinegti.com for how to get more (Naturally Aspirated) from you engine eg. quad throttle bodies, or do it the more road friendly way, go turbo :wink:
PostPosted: Wed Oct 08, 2008 12:51 pm
FlyingGrape wrote:
suzimonster wrote:
Hello Lander...
Suzimonster
Last time I used turbo already, but not economical and leaks everywhere and some more, the always show engine light when I'm cruising.. but the power is really make me mad.. but not realiable during road use.. So, after my engine leaks everywhere and started cougfing then i change to standard back with port and polished. but then still not satisfied with it.. really wanna make my machine a monster with NA.. hahaha.. i always been bullied by the Vtec.. they always condemed my car.. then i wanna teach them how powerfull suzuki swift are.. :twisted:
PostPosted: Thu Oct 09, 2008 2:07 am
Hi Lander,
I'm in the process of rebuilding the engine for my rally car here in the U.K, I already have the bottom end sorted i.e new H beam steel rods, 12:1 forged pistons etc etc.
My question is what have you done to the top end i.e the head and what cams are you running.
I have a set of ITB's ready to go on with a fully mappable management set up, the cams I currently run are 290 degree with 8.8mm of lift and fitted with adjustable pulleys.
Any advice would be appreciated.
Andy.
Drive with commitment or bloody go home!
PostPosted: Thu Oct 09, 2008 3:56 am
swiftmotorsport wrote:
Hi Lander,
Andy.
I am runing STOCK pistons, stock lightened, shootpeened rods atc...
About head, it did my friend, all holes are biggers, that is all what I am able to tell you :-) I am using regrinded stock cams 290/290 9,5mm lift! ITB is 4*42mm
PostPosted: Thu Oct 09, 2008 4:49 am
Highlights Násedlovice
Lander
PostPosted: Thu Oct 09, 2008 7:10 am
Many thanks,
mine shouldn't be a million miles away from your type of power then (same size ITB's etc), if mine makes 160hp and that kind of torque I'll be over the moon :D.
Cheers
Andy
Users browsing this forum: Majestic-12 [Bot] and 3 guests
