It is currently Thu Feb 22, 2018 2:15 pm
PostPosted: Wed Feb 03, 2010 2:55 pm
Started removing corroded brake pipes today. Then noticed that some of the fuel pipes are corroded aswell :shock: .
Can anyone tell me how hard it is to drop the fuel tank? If its pretty straight forward i might try to replace the fuel pipes too,
Thanks
INCREASE THE PEACE
PostPosted: Wed Feb 03, 2010 3:43 pm
easy
theres 4 or 6 bolts around the seam that bolt up to the body
08 Civic Wife's car
PostPosted: Wed Feb 03, 2010 4:22 pm
4-12MM BOLTS ATTACH TANK TO CAR,remove fuel tank filler hose&clamps,use a floor jack n block of wood to drop tank,watch fuel lines and electrical connections,and GRAVY!!! its out!PS-empty tank as much as you can,gas everywhere sucks,makes you silly/cross-eyed :buzz: :drunk: :vibe: =)
89 1.0 turbo firefly
2"exhaust,no cats/resonator
3 tech 6*gear
3 tech turbo grind cam
gti brake swap
92 white metro lsi vert
PostPosted: Thu Feb 04, 2010 1:45 pm
Cheers fellas :D
INCREASE THE PEACE
