It is currently Mon Feb 19, 2018 7:18 am
 Post subject: Oil Dipstick Lenght
PostPosted: Sun Sep 12, 2010 5:36 pm
Hello I bought a GTi Without the dipstick. I made a dipstick in my lathe but now I need to know the lenght of the dipstick as I do not have access to oem parts here.
 Post subject: Re: Oil Dipstick Lenght
PostPosted: Sun Sep 12, 2010 7:07 pm
I can measure my original for you tomorrow.
I made one for a friend out of the SOHC by relocating the rubber stopper and shortening the tip.
There is a reason Suz. used a thick flexible wire -- the tube is bent and I had to shave metal off the sides so the blade would bend !
looking for:
PostPosted: Sun Sep 12, 2010 7:29 pm
X= 16"
Y= 15/16"
Z= 3/16"
PostPosted: Mon Sep 13, 2010 10:11 am
airwerks wrote:
X= 16"
Y= 15/16"
Z= 3/16"
:goodpost:
Here's our MK3's:
X= 16" or 40.7 cm
Y= 13/16" or 2.1 cm
Z= 3/16" or 0.5 cm
Had to double check; yep.
The MK2 measures out the same.
What year is yours?
Kinda grainy, but you get the idea:
(might be a tad over 13/16th, eh?)
PostPosted: Mon Sep 13, 2010 10:54 am
:goodpost: Phil
looking for:
PostPosted: Sat Sep 25, 2010 11:39 am
mine is a 1995 GTI. thanks all for the help.
PostPosted: Thu Apr 21, 2016 4:59 pm
Could there possibly be a difference in length on a MK1 engine ?
