It is currently Thu Jan 18, 2018 5:22 pm
Post new topic Reply to topic  [ 62 posts ]  Go to page 1, 2, 3  Next
PostPosted: Wed May 23, 2012 11:50 am
Hey Guys
I have converted my race car to a high compression, N/A on CBR ITBs and bored to 76mm. Some pic of the N/A conversion can be seen here ->http://flic.kr/s/aHsjuPyyXv.
I have entered the engine specs into Dyno2003 software just to see what it generates. It yields 180HP at 7500rpm :shock: See the attached give me your feedback.
The haltech ecu software is tuned via VE and is presently at 95% w/ ~12.6AFR at 7,500rpm
The specs are:
- Full race cyl head w/ 30mm intake & 27 mm exhaust valvel
- Tighe Cam 793C [10.35mm lift w/ 258* @ .050 (290 advertised)]
- Honda CBR929 ITBs
- Injector Dynamic 715cc Injectors
- JE 13:1 forged pistons
- Pauter Rods
- Lightened, Balanced & Polished crankshaft
- machined & steel plated reinfored mains
- suzukird 4-1 exhaust header w/ side pipe
- suzukird Aluminum flywheel
- suzukird straight cut dog box w/ 49.2 FD
- Haltech PS2000 ecu
- Hatachi Audi A4 Ignition coil on plugs
- J&S 4ch DIS Safeguard
Dyno2003 - MF89.pdf [26.25 KIB]
Downloaded 239 times
PostPosted: Wed May 23, 2012 6:15 pm
Your intake system give me goosebumps :buzz:
PostPosted: Wed May 23, 2012 9:58 pm
wow!! that looks amazing!! I can only imagine how that things must sound!!! where abouts are you from? I see that you went to Guyana last year.
1994 Suzuki Swift GTi
PostPosted: Wed May 23, 2012 10:07 pm
Amazing! Is the car running? Got clips of the car?
2003-EVO7 GT-A
Aruba "one happy island".
PostPosted: Thu May 24, 2012 8:34 am
Hey, it sounds really great at 9000rpms w/ an open exhaust. :D and I from Barbados ;)
PostPosted: Thu May 24, 2012 8:38 am
Yes the car is running, but I don't have any clips as yet. Will post some as soon as I get.
I am more concerned about the suggested HP figure. Does it seem realistic or close to realistic? Unfortunately, I don't have access to a working dyno here in Barbados.
PostPosted: Thu May 24, 2012 3:10 pm
NICE!! I'm coming to Barbados for the All Stage Rally next month, maybe I can check you when I get there, I would really like to see the car :mrgreen:
PostPosted: Thu May 24, 2012 7:05 pm
No prob Swifted ... just pm me when you're here and we'll link ;)
PostPosted: Thu May 24, 2012 7:20 pm
cool 8)
PostPosted: Thu May 24, 2012 11:08 pm
Absolutely awesome!!! I am wanting to get a set of high comp pistons for my race motor too! Did custom order them from JE or did u get them through SRD?
PostPosted: Fri May 25, 2012 2:06 am
180 hp is possible but I would expect it to be at 9000-9500rpm, Tony Marsh, a well known and reputable engine builder here in NZ only managed a true 175 hp on his engine dyno and that was dry sumped and running close to 10k rpm, remember a 1299cc hayabusa makes 175bhp at 9700rpm.
Just looked at the calculated dyno chart, I would expect to see a much peaker hp graph, nice looking crank btw 8) , would gain a couple of extra hp I would think.
PostPosted: Fri May 25, 2012 9:12 am
Oh wow, I was waiting for you to post up your full build in a thread Colin. Imma gonna be all over this thread like sugar on candy!
I absolutely love your crankshaft assembly. Is there anyone across in BIM that does the knife-edge and balancing of the crank?
~the other Ralph~
Certified Suzuki Owner:
PostPosted: Sun May 27, 2012 10:47 am
Valvespring valve spring 9.000 rpm original :?:
PostPosted: Mon May 28, 2012 9:26 pm
There is nothing standard in the motor. The valve train is lightened with upgraded valve springs. Actually, it has the suzukird Full Race Titanium & Speciall Alloy Valve Train Kit
PostPosted: Tue May 29, 2012 1:37 am
MF89 thank you very much :wink:
Valve Train Kit $1479 :oops:
PostPosted: Tue May 29, 2012 1:15 pm
Yeah but he races for gold, not money. :lol:
~the other Ralph~
PostPosted: Tue May 29, 2012 4:22 pm
I wish - lol ... nonetheless, contrary to popular belief... reliability and performance doesn't come cheap. 8)
I took part in a local 1/8mile drag meet yesterday (28th May) and my best time thus far is 9.027sec using 15x7.5 yokohama ADVAN AD06 tires. I am confident that with better tires and suspension tweeks the car can do an 8.800 - 8.600 1/8mile run. My reaction time is also off at 0.249 as this is the first time using the lights. 0-60 2.151. Hopefully there should be a video of the runs soon.
A few pics...
28.May.2012-1.jpg [74.95 KIB]
Downloaded 1294 times
Video...
The Slip...
Cheers
PostPosted: Tue May 29, 2012 5:01 pm
I must say the car is moving like it has 180hp :o so your dynoplot may be closer than we think!
PostPosted: Wed May 30, 2012 4:26 am
http://www.youtube.com/watch?v=ofC7nv5s ... re=g-all-u
Car can be seen at 1:25 & 2:41 :)
The other white swift at 2:51 & 3:23 was the underdog of the day continuously beating on the turbocharged honda :D
PostPosted: Wed May 30, 2012 2:41 pm
Latest pic of the engine bay:
DSCN5079(sm).jpg [129.59 KIB]
Downloaded 1266 times
PostPosted: Wed May 30, 2012 4:38 pm
...drools :shock:
PostPosted: Wed May 30, 2012 10:52 pm
Imma call your car the “red bat outta hell”.
Btw,
What’s that in the pic just to the right side of the upper rad. hose, that’s sitting where the battery normally would?
~the other Ralph~
PostPosted: Thu May 31, 2012 12:05 am
Btw,
It an electrical power steering pump off the 2005 mini cooper 8)
PostPosted: Thu May 31, 2012 12:51 am
Aah....if I had to guess, I would have said a Water/Meth injection pump. Not a far away guess I suppose.
~the other Ralph~
PostPosted: Sat Jun 02, 2012 3:00 pm
MF89 wrote:
Btw,
what rack are you using?! I would love to get power steering in my GTi(the LSD kills me :-S)
